Question about Car Audio & Video
I have a dual cd player model xdm7615 and i dont have the wiring harness anymore and im gonna solder on some new wires...could u tell me what wires go to which pins thanks
  • 7 Answers
SOURCE: Connector Pin Out
Posted on Jul 21, 2008
  • 4 Answers
SOURCE: Audiobahn ATB8AT
I had the same problem. I looked everywhere and could not find the right type of harness. You may be able to find a similar sized harness at a local electronics store that you could, possibly, slightly tamper to make work, but the easiest thing i found to do was I took the amp out of the box (it's only the ciruit board) and very carefully soldered the ground, remote, and power wires directly onto the pins on the plug. I cut the wires I soldered on down to about 4 inches and then used wire nuts to attach the actual wires coming from my HU, battery, and ground.
Posted on Nov 19, 2008
blueextc3221
  • 15935 Answers
SOURCE: what to hook the dimmer wire & illumination wire to
Those lower end Sony models dont use a dimmer or illumination. The display is constantly one brightness level.
Simply terminate or tape off those wires from the plug.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 17, 2009
axlman55
  • 12 Answers
SOURCE: cant hook up car stereo
this is an easy one... go online and google search -color codes for whatever your car is stereo wires
Posted on May 05, 2009
  • 12 Answers
SOURCE: Need wiring diagram for harness
1) Black Ground
2) Red 12V Ignition
3) Yellow 12V Constant
4) Orange Illumination
(Sometimes there's an extra orange for cell phone mute)
5) Blue Remote
6) Blue/White Power Antenna
7) White Front Left
8) White/Blk Front Left
9) Gray Rear Left
10) Gray/Blk Rear Left
11) Green Front Right
12) Green/Blk Front Right
13) Purple Rear Right
13) Purple/Blk Rear Right
Posted on Jul 08, 2009
I have dual cd player and i need the wiring code chart
did yuo get a wire harness for you make/model of car? it should come with it
Apr 07, 2010 | Dual XD-7500 CD Player
Putting cd player in 94 explorer?? HELP PLEASE?!?!?!?
Yes, that would be fine, make sure you solder the wires and tape well or use shrink tube on the connections.
Mar 13, 2010 | 1994 Ford Explorer Limited
I don't know which wires do which to install the Dual XD6300 - radio / CD player into a Saturn SL1 I have the schematics for the saturn I just need to know what each wire color does.
GO PURCHASE THE WIRE HARNESS ADAPTER FOR THE CAR FROM PEPBOYS AND THEN EVERYTHING IS COLOR CODED FROM THAT CLIP TO THE RADIO CLIP DO NOT ATTEMPT TO CUT THE STOCK CLIP OFF FOR THE $15 UR GONNA SAVE IT IS NOT WORTH IT
Feb 27, 2010 | Car Audio & Video
Need a wiring diagram for my 92 volvo 940 gl
Go to the following site and enter the make and model of your vehicle and it will give you a free diogram of the wiring to your stereo. The colors do not have to match up.
Apr 04, 2009 | Dual XDMR-7700 CD Player
How do i connect the wires to put in new cd player in 95 aurora
ok you nee d to go to walmart or your closest car audio center and purchase the wiring kit for your year model vehicle the kit will have the plugs to plug into your factory harness do not cut your wires these plugs will have the wires labeled wire them to your new radio and it should plug in and play you may also need to aquire a face kit for mountring the sterio
Mar 01, 2009 | Dual XD-7500 CD Player
Need a new wiring harness for my Dual XDMR7710
Look in your local phone book yellow pages under stereos for a local (not big name) stereo installation store (there will be one) and go there.....you will thank me!
jack
Feb 22, 2009 | Dual XDMR7710 CD Player
How to install a durabrand 60 watt car cd player?
the easy way is to buy a 5$ harness from pepboys or a auto stereo store ask them a harness for your make and model car to hook up a after market radio that harness will plug into your factory harness also the new harness will give you a wire diagram telling you what wires are what if you dont know about what wires are what on your after market radio they are sometimes listed on the top of the radio its real easy most radios are red power yellow aux -only power when ignition is on and black ground speakers are most of the time one color for all negitive and multi colored for positive good luck I hope this helps good luck....
Dec 31, 2008 | Durabrand Car CD Player and AM/FM...
Installing CD Player
i supose the am fm radio just dosnt cut it anymore well lets give this a try . first u must disconnect positive battery cable so you dont short any wires . remove screws that hold in factory radio pull radio out a feww inches as no to rip out any wires.next you must locate positive 12 volt power supply wire usually red or orange .if not shure connect battry cable again and use a 12 volt test light by attaching the ground cable on the test light to a good clean metal bracket under dashboard or connect to a black groundwire with a screw into the steel under dash next probe the wires goin into the factory radio ur looking to find power 12 volts once you have found the correct power wire use tape and mark it this will be the power wire for your new stereo next u must figure out what wires for what speakers osually 2 wires per speaker 2 rear speakers and 2 front speakers meaning a total of 8 wires follw me so far ? now disconect car battry again so not to have sparks and cut or disconnect remaining wires speakers first label all with tape and mark front right front left rear left rear right there is a + and - the wire with the stripe on it is usually the + the other wire is the - being negitive ground . this operation is important in order for your fade ballance controlls to work properly now with your new cd player inhand look and see what wire is gonna be 12 volt most times its red with a fuse eg white plastic connector small fuse inside there it a must proper fuse to protect new cd player now there will be a black negative this will go to the matal ground area under dash close to where cd player goes into dash red to the orig taped 12 volt supply now ur spks one pos+ and one neg or common to each speaker now make all conections with stereo before you push stereo into dash you must hook up car battry leaving cd player hanging out so you can make wire changes if you wish on the speakers you need to use one pos front right or rear right + with one common or neg black - to the spkr the same common or ground or - whatever its called one common or neg can be used for all spkrs .good luck tape and solder all connections after you feel all is good im sorry this is all the help i can offer you be careful
Jun 12, 2008 | 1978 Ford Granada
Car Audio & Video Logo
115 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
