Question about Refrigerators
Hi, I have a Samsung SR503NTS Fridge Freezer. It has stopped cooling the fridge section. The freezer section is working fine. I pulled the back out of the freezer compartment, exposing the cooling coils etc, which were partially iced up. I have defrosted this area, however the fridge section is still not cooling after 12H.
  • 1 more comment
  • fixya125 Sep 08, 2010
    Hi, It is a freezer on top, fridge below. It only has cooling in the freezer compartment and a fan in the freezer compartment. I just pulled the top back off the fridge section. There is an actuated flap that controls the flow of cold air and it moves ok. it opens full immediately after pushing in the door switch, and closes when the door is open.
    I have just left it in an open position and disconnected it to see if the fridge now cools. I am thinking that one of the temperature sensors is not working correctly somewhere.
    From googling it appears that faults are common with thermistors in these fridges (thanks Samsung). How can I test the thermistors?
    Thanks
    Steve
    Please see my other comment ... sorry not sure how this system works
  • fixya125 Sep 10, 2010
    Yes I get cold air now from the freezer into the fridge, but the flap only opens for a few minutes and then closes again. It seems to think that the fridge is already cold, but it isn't.
    What now?
  • 4,070 Answers
Most samsung have a separate evaporator coil just for the fridge side. Check it out. If it's the other kind then The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Sep 08, 2010
  • Charles T Nevin
    Charles T Nevin Sep 09, 2010
    With the flap open and the fan running you should get cold air to the fridge compartment.
    Concerning the ice build up. A light frosting is normal. It gets melted by the defrost heater when it's time. A partial covering of ice is a sign of the system being low on freon. A heavy covering all over the coil is a sign the defrost system isn't working.
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
My samsung fridge section stops cooling but freezer is working
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Samsung Refrigerators
Hi, I have an LG refrigerator, the top freezer works fine but the fridge section has stopped cooling, I turned the unit off and next morning there was a large puddle of water on the floor, when I turned it...
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
Feb 15, 2010 | Refrigerators
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Refrigerators Logo
190 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
