I have a craftsman lt1000 model 917272761 motor size i 17.5hp. While I was mowing the lawn the tractor died. I have checked the spark,it is sparking. I have also checked the fuel and it is getting fuel. When you turn the engine over the starter does engage the flywheel and both the flywheel and starter turns. any idea
Where is the spark plug
In the cylinder head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Try leaving the fuel cap loose, its possible you have a blocked fuel cap vent which can be cleaned with compressed air. Also if it still dies,check to see if you have spark while its hot. Also check for correct valve clearances. Hope this helps, regards Phil.
check the oil level might have low oil sensor on it. Also make sure the engine is clean (no built up oil and dirt on the motor itself or the fins on the motor)
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
