Question about Refrigerators
We moved our Whirlpool Regal No Frost refrigerator across the room 2 days ago. The power was off for no more than a minute, but the freezer is still not cold. I can hear it working.
  • 159 Answers
SOURCE: refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Posted on Jul 12, 2007
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
SOURCE: 5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Posted on Mar 18, 2008
22yooper
  • 828 Answers
SOURCE: Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Posted on Jul 16, 2008
I have a whirlpool bootom freezer. The refrigerator portion keep getting warm while maintaining the temp level in the freezer remains constant.
John
It looks like you are getting frost/ice build up in the air vents( freezer is what cools your refrigerator side. If the ice blocks the flow up no air can travel to the other side). You removed the blockage by defrosting it but it will probably come back if the door does not seal properly. The only moisture you can introduce to the freezer is from outside...
Hope that helps
Cheers
Jul 04, 2017 | Whirlpool Refrigerators
My whirlpool gold refrig is icing on bottom of freezer. Is there any way to fix it without removing the back panel of the freezer?
You may need to manually defrost it, Even a frost free freezer can get frost. After you do that, make sure that you leave enough room for air to flow around.
Feb 11, 2015 | Whirlpool Refrigerators
I have a Whirlpool refrigerator that the coils in the back of the freezer sometimes glow red. Is this normal?
Yes that is absolutly normal what it is,is the defrost heater cominh on to melt built up frost. It's on for around 20 minutes every 2-3 days at various times of the day..one time its on at 12 noon,the next time its on a 3 am ect
Aug 20, 2011 | Frigidaire FRS3R5EMB Side by Side...
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge at room temp
Good day,
two common reasons fro this.
1. The fan motor in the freezer compartment has failed and is not driving air to the fresh food compartment.
2. The second common problem is the defrost system has failed, blocking air from entering the fresh food compartment.
First indication is frost building up on the rear panel in the freezer. Remove rear panel and inspect.
Here is an excellent tutorial on defrost system repair.
http://www.appliance411.com/faq/howdefrostworks.shtml
Dec 04, 2009 | Whirlpool Refrigerators
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Not cooling or cold
The REFRIGERATOR WAS MOVED TO ANOTHER SITE. AND IT HAS NOT GOTTEN COLD SINCE MOVE, PLUB UP 2 DAYS AGO. iT WAS UNPLUG AND CLEAN 2 DAYS BEFORE MOVE. COULD IT NEED ANTI-FREEZE?
Aug 25, 2008 | Whirlpool ET1FHTXM Top Freezer...
Warm side by side freezer and fridge
hi thanks for your question. i would clean the coils at the back of the fridge. it could be just dusty try that
Aug 23, 2008 | Jenn-Air JCB2388G Side by Side...
My whirlpool refrigerator (Model ET18DK) was moved downstairs a few months ago. The top freezer and the refrigerator only cool a little bit now. The freezer is about the temp that the refrigerator should...
check for:
  •  any ice or frost buildup in the freezer (defrost problem)
  • airflow restrictions, like dirty coils or if the refrigerator is on carpet.
  • it could also be a weak compressor.
let me know Mike
Aug 08, 2008 | Whirlpool Refrigerators
Fridge and freezer not cold enough since we moved
remove the panel at the reaar of the freezer. you should have a full frost pattern on your evaporator (frosted not snow packed) and the fan should be running. if you do not have a full frost pattern then you have a sealed system leak. covered under the first five years of your warranty
Feb 17, 2008 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
