Question about New Balance 1400 Treadmill
I have a NB 1400 Treadmill that is shutting down and giving the E1 code in the display. I see that there is a solution that says it is a sensor code. What sensor and what is the solution to fix the problem?
  • 79 Answers
The sensor is one that records the movement or speed of the belt, some machines are located next to the engine flywheel. and other off the front roller pulley on the left side exactly. physical form depends on the manufacturer and the only solution is to buy, where somewhere distributing or selling accessories for treadmills
Posted on Sep 10, 2010
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
I have an older NB 1400 Treadmill (7 years old)
Motor controls for New Balance can be found by doing a Google search on Treadmill Analyzer and look for the MCB List page of repairs offered :-)
Jul 15, 2014 | New Balance 1400 Treadmill
Treadmill E1 Error
Version:1.0 StartHTML:0000000168 EndHTML:0000001348 StartFragment:0000000468 EndFragment:0000001331
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
clean the speed sensor, test for open or faulty. tight the connector very well. RUN the software calibration for easy troubleshooting and fix it.
see the diagram attached. and follow steps.
God bless you
Version:1.0 StartHTML:0000000168 EndHTML:0000003648 StartFragment:0000000468 EndFragment:0000003631
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Mar 29, 2013 | Exercise & Fitness
My treadmill showing E1 error code
ERR 1 - Motor Movement
Tes the s. sensor for open or faulty. Clean it + tight the connector very well and try again. see the diagram for adjust.
God bless you
Feb 04, 2013 | Quantum Exercise & Fitness
Code e1 on my treadmill
please see the indication for error 1. and fix it. see the block diagram
Lube the Deck belt and rollers bearing too.
Jan 01, 2013 | Fitness Equipment Estore Bremshey Scout...
I have a Tsc4 treadmill that has worked perfectly until now, when it shut down displaying a E1 error message...any ideas on what to do? Thanks :)
E1 Is an RPM sensor error message. It simply means either the belt is not moving or the sensor is defective.
If the belt moves slowly then shuts down, check the RPM sensor located close to the drive pulley (under the motor hood). verify that it is as close to the pulley as possible without making contact. Verify that the magnet is present (mounted on the pulley). it will be a small round magnet, 3/8-1/2 inch diameter. If the magnet is missing, it may have attached itself somewhere on the treadmills frame. Reinstall it in the pulley.
Often there is an RPM LED located on the controller PCB. By manually passing the magnet past the sensor, you should see the LED flash. If so, that verifies the operation of the sensor, if not replace the sensor.
If the belt doesn't move at all, likely the motor controller PCB is defective..
Dec 17, 2010 | Horizon T93 - Treadmill
I havea new balance 1400 I keep getting two error codes on my screen the first is E1 and then A E3 on elevation.?
Hi This is dinesh here,
The E1 Error is for the sensor problem and the E3 error is for the IC crasg in the machine...
Jul 22, 2010 | New Balance 1400 Treadmill
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
Tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
New Balance 1400 Treadmill Logo
391 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Howard
Howard
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
