Question about Intertherm Heating & Cooling
There is ice build up on the inside A coil why is this happening and what is wrong with it. Do we need to have someone come out and look at it.
  • 76 Answers
It's because the refrigerant is low. Yes, you need to have someone come
recharge it.
Posted on Sep 08, 2010
Water leaking on the floor. The unit cannot be opened to empty? What is wrong
Check to see if ice is forming inside. If so, check filter. Blocke filter restricts air flow and ice builds up on coils then melts slowly with heat from room.
Aug 05, 2013 | Kenmore Heating & Cooling
How to fix ice build up on the evaperator coils of a window a/c unit
Your in the wrong form group!
"Problem with Microsoft Windows XP Home Edition"
Seems you need to in form group "window a./c evaperator coil ice build up" Not windows computer XP issue! Check it out.
Aug 21, 2010 | Microsoft Windows XP Home Edition
We haave a samsung sisen by side model rs277. It is not making ice very fast, We can not find our manual. What might be wrong, or is there a way to make ice faster?
Hello and Welcome to FixYa!
Please do elaborate a bit, what you exactly mean by "it is not making ice very fast". I assume that you want to say that its not cooling the way, it is used to be ( Please Correct me if I'm Wrong). That shows "poor cooling" symptom.
The Poor cooling that you are facing might be caused(In fact the most common reason) due to the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing/opening the panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer that is exactly the thing you quoted. Such a frost build-up usually shows a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed/designed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (usually a bi-metallic switch) The defrost heater Also you need to clean the dust, lint from the condenser unit by using a condenser brush or a vacuum cleaner to remove all the dust from the unit (it is usually located at the back of the refrigerator). If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. If the problem still persists and the above quoted techniques/tips didn't work,You may need a qualified appliance repair technician to further diagnose the problem.
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 17, 2010 | Samsung Refrigerators
LG Frige builds up ice in bottom of freezer.
though this qestion is old, it might help someone
Here is a fix with images
Have fun
Avi
Oct 23, 2009 | LG LRFD25850 French Door Refrigerator
Kenmore Elite ice maker doesn't work
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
If it still exists then there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Sep 25, 2009 | Kenmore Refrigerators
Ice maker won't work and freezer is not freezing good
Take a look inside the freezer at the back wall. See if there is ice built up on it. If you have ice or frost on the panel, you either have a bad fan are you having a defrost problem. If I had to guess I would say a defrost problem. Unplug the fridge and remove the panel. Use a hair dryer to defrost the ice. There is a coil inside the ice so DO NOT TRY TO CHIP THE ICE OUT. just take the time and defrost it. After that is done, if you know how to use a multi-meter. You can check the heaters (Found inside the coils) to see if they have continuity. I would bet they don't. If I'm correct, you will need to replace the heater. Until you get the part or have someone to repair it, you can replace the panel, plug it back in and your fridge will work normally for around three days or until the coil builds ice back on it. This will give you time to either fix it or have someone to take care of it for you.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice building in freezer and water leaking in the fridge section
I will say that you may have to call someone in, but it is most likely the thermostat for the freezer, when the freezer reaches setpoint, that stat will kick the compressor off, but it sounds like yours is running until it the coils freeze, which brings another problem in hand is a dirty coil. Those two are your best bet. Best of luck!!
Feb 15, 2009 | Refrigerators
Ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Feb 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice or frost on the inside coils of the ac unit
Reduced or no airflow, Evaporator may be dirty. Low on freon.
Jul 31, 2007 | GE AJCQ08ACB Air Conditioner
Heating & Cooling Logo
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
