PLASMA TV MOD PDP32H1ENV UNIT POWERS UP NORMAL PICTURE APPEARS FOR ABOUT 2 SECS THEN GOES INTO PROTECTION (SHUTS DOWN)GREEN STBY LIGHT FLASHES. NOTE! COOLING FANS NOT OPPERATING. CAN THIS BE THE PROBLEM? I HAVEN'T GOT ANY SERVICE INFO YET DAVE FARR, BIFARR AUDIO VISUAL bifarr@tiscali.co.uk
  • 1 more comment
  • motorman47 May 14, 2008
    THIS IS NOT ON LONG ENOUGH TO GET EVEN SLIGHTLY HOT, ABOUT 2 SECONDS
    Its been off all day, the psu is working OK for 2 seconds it, then just goes into protection, a normal picture appears then it powers down It is not overheating as it is only on for 2 seconds.
    I do repair these things as a profession. this particicular model is new to me. I have repaired many makes of plasma/lcd screens inc Philips LG Sony Toshiba etc.and don't have too many problems
    My enquiry is; has anybody had a similar fault on this particular model as I haven't any service manual on this model, and is it that the cooling fans are not opperating causing it to go into protection? As their non opperation may be activating the protection cicuitry. This is the case with some computors etc.
    Master:
  • 351 Answers
Dear Dave,
yes this is also a fact because the PCB become heated very son in these models so preventioally they shut off if the cooling fan is not work that time. here i suggest you please contact any authorised service centre to rectifird this proble
regards
Posted on May 14, 2008
    Genius:
  • 3,422 Answers
HI,
Did you try a hard reset? unplug all the cords for 4 hours and then plug it back.This will restore the factory default settings.If this doesn't help then you will have to get it repaired since it is switching to protection mode to avoid any further damage to it.
Goodluck..
  • 1 more comment
  • Priya darshan May 14, 2008
    I would strongly recommend you to get it repaired.But if you need more assistance you can rate us thanks for trying and go with other expert's opinion.I
    ok,Please give me few min. i'll let you know if there is a service manual available for this model..
    ok,I have serched for the service manual but i don't think it is available for download.Anyways i suggest you to go for the other expert's opinion on this.All you have to do is rate our solutions as "Thanks for trying" and your problem will be posted again..
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Plasma tv picture not coming on and power light flashing
Yes, you have power supply issue.
the power on circuit is malfunctioning and the flashes is the indication that the voltage levels for the power on regulation is not correct therefore shut down to protect the circuit from further damage. You TV unit needs servicing by an plasma TV specialist.
Also check to see if you do not have the TV in sleep or hibernation mode.
Apr 22, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
TV picture and sound goes off--leaving a blinking green light showing as on (power). Several times in the last week I have shut the power strip off and then on again and the TV went back on with the solid...
If TV goes off and the led stays blinking, that is because the TV is going on protection.
Protection is a special diagnostic mode that starts when an internal fault has been detected.
If this happens erratically while you are watching TV, then parts that can commonly cause the problem are PSU board, main board or digital board, ballast board and converge board on DLP, inverter on LCD, low buffer and sustain boards on plasma.
May 14, 2009 | Televison & Video
Power will not stay on
With a problem like this, I would use the warranty for the TV.
It's possible a circuit board failure has occurred and the TV is automatically turning itself off to protect it from further damage. Is normally called " Protection Mode " for most TVs.
Being that it's 2 months old, it should be under warranty regardless. I would recommend contacting the store of where it was purchased and have them help you with the warranty issue.
May 04, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Airane
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Jan 26, 2008 | RCA 32V524T TV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
