Question about Toshiba Satellite A135-S4527 Notebook
Laptop stuck in sleep / hibernate mode??
Pressing the power button, both blue power LEDs light up. After about 2 seconds the HD LED blinks once (very quick) and that's it. No other activity at all.
Same results on battery or AC adapter.
Any ideas?
  • cdstagg May 19, 2008
    I have tried that, and have also removed the battery and let sit for several minutes before replacing - same results.
    Also - noticed over the weekend that when power is turned on, the fan (bottom side) kicks in for about 5 seconds, and then quits.
    Thanks,
    Chris
  • 36 Answers
Try holding the power button down for at least 10 seconds, that should turn off the laptop completely. Then press the power button again to turn it on. Hopefully it will boot up.
Posted on May 19, 2008
Umm no its the pin bro, the pin got stuck your laptop still thinks its in hibernation mode, you have to dig out the pin
Posted on Aug 15, 2008
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
I have an EVESHAM MS-17188B Laptop. Stuck in sleep mode! The Problem is when ever I turn it on, the power and sleep mode light is active. But nothing else, the screen stays blank, and cant hear any fans...
First advice would have been to remove battery, but since you did that, I'd say that your laptop is stuck in hybrid-sleep, or the old hibernate. Try pressing the power button for 10-15 seconds, the laptop should go off, then try presing the power button again, for normal boot.
May 05, 2011 | Computers & Internet
Cant print anymore print counting is almost full. how to reset count
try this
Manual reset methods several EPSON Stylus Color. Actually there are two methods to reset epson printers counter, that is using software resetter such as adjustment program or SSC service utility or using manual by combination pressing button on the printer. If Reset using software resetter you can follow the way of usage the software but sometimes software resetter for the printer is not available. The only way to reset the printer if software resetter not available you can use manual reset.
The Following manual reset for some EPSON Stylus Color Printers:
1. EPSON Stylus Color
Pressing and holding ALT+FONT+LOAD+PAUSE buttons combination
press POWER button
Release all buttons
2. EPSON Stylus Color 300
3. EPSON Stylus Color 400, 600
Pressing and holding LOAD/EJECT and CLEANING buttons
press POWER button and hold it until you will see blinking INK OUT and PAPER OUT leds
Release all buttons
In 2-3 seconds time press LOAD/EJECT and CLEANING buttons again.
4. EPSON Stylus Color 440, 640, 740, 460, 660, 670, 760, 860, 880, 1160
press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
5. EPSON Stylus Color 680
Pressing and holding LOAD/EJECT and CLEANING buttons,
In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
6. EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons
press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
7. EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led
Release all buttons
8. EPSON Stylus Color 800, 850
Pressing and holding LOAD, CLEANING Color and CLEANING Black buttons
In 2-3 seconds time press and release CLEANING Color button, You will see leds blinking.
9. EPSON Stylus Color 900, 980
press POWER button, You will see blinking INK OUT led
Release all buttons
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
10. EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons
turn on printer.
Mar 17, 2011 | Computers & Internet
I wiped off my computer keyboard and did npt notice anything happened when I did. When I went back to use the computer, the yellow "sleep" light was on as it usually is after sitting a while. I...
You might have put the computer into hibernate; have you tried pressing the power button? It should wake the computer up if it is asleep or hibernating. It is also possible that your monitor cable is unplugged.
Mar 07, 2011 | Sony VAIO PC Desktop
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
Appears to be stuck in sllep mode, sr2020nx
unplug computer if necessary. Can also hold the power button in until it shuts off. Then you might want to to turn hibernation off in your power settings in your control panel.
Oct 25, 2009 | HP Compaq Presario SR2020NX PC Desktop
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba power led flashing yellow
This flashing LED usually means only two things, both are quite harmless:
1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
good luck.
Toshiba Satellite A135-S4527 Notebook Logo
1,602 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
