Question about Ovens
90cm Gas cooktop / electric oven. The Outside glass of the oven door has come away from the seals and needs to be repaired to operate efficiently.
  • Ovens Master
  • 3,083 Answers
I don't have enough information to really provide you with diagrams, but I can guide you to some sites that may be of help to you, and here is one:
http://www.appliancepartspros.com/
Enter your model number at that page, and you will have diagrams of available parts (if they have your model).
I'm pretty certain they won't repair the door, and will want you to buy the whole door, but you might check with an appliance repair shop and see if it's possible to get just the glass.
This site has some good information that might help you also:
http://www.repairclinic.com/Range-Stove-Oven-Repair-Help
Good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 08, 2010
Where can I get a heat resistance double sided tape to affix the external glass of the oven to the SS frame on my slide in GE stove .
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
Apr 27, 2015 | GE Ovens
Outside door glass has slid down
Sounds like the door gasket/seal has pulled away from the rest of the door frame and layers. You might be able to take the door off of the hinges, and cabinet, and take apart the layers to readjust.
Dec 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I just had a Frigidaire electric Single Wall Oven (FGEW2745) installed under a Bosch gas cooktop. The cabinet maker didn't allow enough room for the oven so my contractor had to lower it. However, as...
Any handle you replace on the oven will certainly void its warranty, especially if you have to drill the door to fit it. Generally the oven handle is designed for the oven, and as such most manufacturers dont make different door handles for them. Most likely you will need to get a different oven altogether, or void your warranty and find a suitable handle and attach it to the oven door yourself by some means.
Hope that helps.
Feb 24, 2011 | Frigidaire FGEW2745KB FGEW2745KW Electric...
I have an old hotpoint oven model rb525j2. I am trying to repair the door gasket. I have the part, the old one seems to be rotted away in the seal and I have no idea how to take the old one out, much less...
Most ovens have 4 or more screws, that tighten the inside and the outside of the door together--
Also-- Most doors can be removed, and laid on the floor, or on the bench--
Either way The door needs to be in a location you can get to those screw.
Separating the inside from the outside will allow access to the glass, and the door gasket.
Let us know what you find when you get this far..
Mack B
Dec 27, 2010 | Ovens
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
How do I get the inside glass panel back onto the door?
You will find sets of screws ether on the outside edge of the door OR on the inside panel. You can NOT! use any glue to "seal" the Glass this will make everything smell like the sealant you picked to use. your door was probably used as a resting spot for something heavy and caused the doors skin to be bent OR when you Cleaned the oven with the clean feature it caused the door to warp. Your option is to get a replacement part to fix the problem you can stop by any appliance parts shop and ask them what the best thing to do is and/or buy the part there you can "pull the door" off the hinges by lifting the door straight up at you and take the part to the stop for help and or replacement
Feb 10, 2010 | Zanussi ZBF360 Electric Single Oven
Condensation in oven door glass after steam clean
No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
Jun 30, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Smeg 90cm oven - removing inner glass plate of door
First you have to unmount the door from your oven (descriped in the manual how to do).
Then next, remove the screws that you have mentioned already of the inside of the door (the inner glass plate is mounted by adhesive on the outer part of the door). After yo have removed the screws, the inner door can be parted from the outer door. Wupti - now you are able to clean the inner side of the glass platen of the oven door.
Per Oding, Denmark
Jan 06, 2009 | Ovens
Thermador 6 Burner cook top
It sounds as though you have soem nice, well sealed cabinets and a good installation on your cooktop. When you open the drawer. it creates a momentary vacuum that sucks the oxygen away from the cooktop, as the bottom of these are not airtight. The only thing you can do is to open the drawer more slowly or have a vent of some sort installed in the back of the cabinet to let air in as you open the drawers, so it does not suck it from the top.There really isnt anythig wrong per say, it something that happens with most gas cooktops with drawers/ doors below them. Hope this is helpful.
Dec 27, 2006 | Thermador SMW272 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
