Question about Weber Q Grill
I have weber q200 grill and only 2/3rds of the burner will light. what is causing this?
I had the same problem with my Weber Summit grill. The problem was traced to spiders getting into the igniter gas tube attached to the valve. You have to loosen the gas valve manifold to get a view down into the tube. Cleaning out the clog solved the problem.
Posted on Oct 11, 2010
  • 43,501 Answers
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 08, 2010
How do i light weber Q200
Q200 has a red piezo module in the support leg on the side.
Oct 06, 2014 | Grilling
Model Q200, Propane model Get no flame on the burner. Apparently, getting no gas. Something seems to be stopped up. What to do?
Whether you're using a 20 Lb Propane Grill Tank or a screw in gas canister, the solution to the problem is the same .
1. Be sure you have enough gas in the tank or canister to maintain proper ignition.
2, If the above checks out OK. Turn the LP tank valve OFF or if you're using a screw-on canister
turn the gas valve OFF.
3. Disconnect the hose from the tank or unscrew and remove the gas canister.
4. Wait 5 minutes and reconnect the hose to the tank or reattach the canister to the gas valve.
5. Open the gas valve VERY, VERY SLOWLY (Slow Motion, slow). Once the valve is full open, light
the burner & turn it to HIGH. Did the burner light and does the flame height look correct?
If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly.
if the above didn't solve the problem, you will either need to replace the Hose/Regulator Assembly or the Gas Valve/ Canister Holder. The Hose/Regulator Assembly you can pickup from any home center or hardware store that sell grills & accessories for about $30.00. If it's the Gas Valve/Canister Holder, you will have to purchase that from Weber or from Factory Appliance Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/weber/q200.html Part # WEB4195 ($29.99) The adapter hose is also available there if you want to make it a one stop shop for $32.99
I hope ths helped you and thanks for choosing FixYa. Happy Grilling!!
Aug 26, 2011 | Weber Q Grill
Weber q200. I replaced regulator 3 times in 3 years using it 1 week each year.
Contact Weber. They have good customer service. A regulator should last "forever".
Jul 18, 2011 | Weber Q100 Grill
Q200 weber grill getting gas flow but only at low and cannot regulate flame or raise temp for cooking
This sounds like a case of the OPD tank valve on the propane tank has locked up your regulator. In which case, turn the tank OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Now, turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the valve is completely open, light the burner farthest from the tank first and turn it to the highest setting. If the flame appears to now be normal, light the remaining burners following the same procedure. If all burners have returned to normal height, you solved the problem. Always remember to turn the tank valve ON VERY, VERY SLOWLY.
If the above doesn't solve the problem, you may need to replace the regulator/hose assembly, which you can purchase from any home center or hardware store that sell gas grills and accessories. Take your old one with your for comparison purposes.
Apr 03, 2011 | Weber Q Grill
After lighting my Weber q200 the gas runs strong for 5 minutes and then starts to get weaker, until it finally goes out. Tank is completely full of propane.
It could be the valve on the propane tank. where the hose screws in the valve on the inside it slides in.It's not opening all the way. un screw the hose screw it back in.
Mar 05, 2011 | Weber Q200
CAN'T USE A 2O LB LP TANK ON THE q130 GRILL
hello. Actually I think you are probably dealing with a new issue related to the newer safety device on the 20 pound tanks. Turn off the tank and unscrew it from the grill hose. Then screw it back on and s-l-o-w-l-y open up the valve. Then light the grill.
You should notice a markedly bigger flame now. Enjoy! J.
Jun 23, 2010 | Weber Q Grill
Both burners are lit , tank is new but tepm wont
Your regulator could be bad or you propane tank is close to empty.
Apr 15, 2010 | Weber Q200
Weak flame on webber q200 grill
Remove connection to tank, reconnect, open valve slowly, when you open valve to fast the tank valve has a shutdown in it, it thinks something is wrong and shuts valve down. Always open tank valve slowly when using.
Also your tank valve could be sticking causing this problem, to fix replace tank.
Feb 25, 2010 | Weber Q200
Just bough weber Q200 grill. Is it normal that the flame burns so low and blue?Used to large flames off conventional grills. Thanks.e.
I have used the Q-series for 2 years. The blue and low flame is absolutely normal. Weber's philiosophy is of avoiding flare ups when grilling for best taste. I love this grill - very easy to clean, uses less gas and makes great food.
Aug 23, 2009 | Weber Q Grill
Weber Q200 connecting to big tank not working
some of the hoses weber has sent out have had prolems if you have already disconnected and reconnected the tank then you should call weber and get another hose
Aug 15, 2009 | Weber Q Grill
Weber Q Grill Logo
715 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
