Question about Technics SA-DX930 Receiver
Fuse locations on Technics SA-DX930
My receiver has sound from the subwoofer, and the 2 rear speakers in surrond sound only. When I switch to stereo, I only have the subwoofer, no front or center speaker. I checked the fuses and they checked out good. I located 4 fuses labeled f1, f3, f4, f5, but I could not locate f2. F1 was located on the circuit board at the bottom of the power supply, and f3-5 were located on the circuit board at the top. Any idea where the f2 fuse could be??
    New Friend:
There is no F2, under the list of components it isnt stated.
Posted on Aug 28, 2017
  • Ivan Filipaj
    Ivan Filipaj Sep 28, 2017
    So on my own, sound stopped coming from optical output and the input switch was all messed up, finally the device displayed error message. I had it checked at local repair shop and as I cocnluded myself there were cold joint all over. And the fact that the recevier doesn't turn on vent for cooling if it isn't on certain volume level doesn't help (there is fix for this on the internet), so if you are listening it at low volume for long time you risk damage from overheating.
  • 2,326 Answers
This model It does not appear to have F2 anywhere, I've checked the service manual and could not find it nor is listed in the parts list.
Posted on May 14, 2008
  • Jaime Hernandez May 14, 2008
    May be coolguy008 could provide a reference designator where the fuse is located.
    If all the fuses check good, I would suggest to check the user guide for the speakers setup.
    Genius:
  • 3,422 Answers
I have got a service manual for you which will help you out.Please CLICK HERE
Goodluck..
Would I be able to connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
Yes, it is hooked up using the (cassette) tape inputs and outputs. Use the tape monitor switch on the receiver to switch the EQ in or out.
Feb 11, 2016 | Panasonic Technics Sa-dx930 A/v Stereo...
Connecting sub speaker to technics sa dx930
Yes, if it only has speaker-level inputs it would require an amplifier to properly drive it. Name the sub and maybe we can answer the second question.
Mar 28, 2010 | Technics SA-DX930 Receiver
Can I hook up my Bose 901s to a Technics Receiver Model SA-DX930?
I don't see why not.. just make sure you observe polarity.. red to red+++ black to black---
Oct 24, 2009 | Bose 901 VI Main / Stereo Speaker
Technics SA-DX930 Sound cutting in and out
try rehooking up speaker wires. make sure no bare wire is showing and positive and negative are aligned correctly
May 19, 2009 | Technics SA-DX930 Receiver
Center speaker is dead or what it can be on my Technics SA-dx930.
More than like, the center channel is turned off on your receiver. Please see page 16 of the manual, which is located here:
http://service.us.panasonic.com/OPERMANPDF/SADX930.PDF
The manual says to do this:
Turn on the receiver.
Press Speaker A and B button at the same time.
The word Setting appears then changes to Front
Press A to select Center
Press B to choose Large, Small or None for your center speaker.
After choosing Large or Small, press A again till you see Complete on the screen.
If this helps, please rate my response.
Mar 26, 2009 | Technics SA-DX930 Receiver
Technics SA-DX930. I ran digital optical cable from the TV to the receiver using the tv/dss mode. It worked well for 4 months. It stopped working. I can get sound out of the receiver and speakers using...
If the only thing not working is the optical input, it is possible that the optical converter is defective. Without seeing the actual unit and testing the IC, I can't say for sure. If you have test equipment, let me know and we will attempt to track this down.
Dan
Mar 03, 2009 | Technics SA-DX930 Receiver
Technics receiver shuting down
check fuse on the inside of the stereo.
Nov 25, 2008 | Technics SA-DX930 Receiver
Probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Apr 24, 2008 | Audio Players & Recorders
About technice sa-dx930
The one plug on the back of the receiver is an rca-type plug and is designed to be connected to a powered sub, which would also have an rca-type input. Even if you connected it, this output carries a line level signal and is not powerful enough to drive a speaker. If your sub has 2 connectors (same as a normal speaker) then you have an unpowered or passive subwoofer. You would either need a powered sub, or to use an external amplifier of some sort...then the sub output from your current receiver would go into the external amp...and the amp connected to the passive sub.
Hope this helps.
Mar 30, 2008 | Technics SA-DX930 Receiver
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out...
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Apr 30, 2007 | Technics SA-DX930 Receiver
Technics SA-DX930 Receiver Logo
553 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
