Question about GE Refrigerators
After about a week have to turn unit off to defrost,then runs fine for about another week
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 08, 2010
Not cooling
either your heating element for auto defrost is broken or your thermostat is is broken
Dec 09, 2013 | Frigidaire Refrigerators
Would a faulty thermostate cause the coil to freeze. On my westinghouse fridge freezer?
To answer your question, no, a faulty thermostat would not cause this to ice/frost up like this after 2 weeks. This issue can be caused by 2 reasons, first check door seals to assure the unit closes completely. This is common with a defrost issue, either the thermostat for defrost has failed or the timer has failed to activate defrost as it was designed to work. Check the defrost system. Send me the model number of the unit you have and I can research the defrost system to see how this could fail within a 2 week period. The ice is to compact to be a seal issue. How much ice or frost was on the false wall/cover you removed to get to this evaporator?
Get back to me so I can point you in the corect direction
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 13, 2013 | Refrigerators
Car stalls when ac or defrost on
Sounds like the compressor is dragging the engine down. The compressor runs in ac and defrost mode. You might try unplugging the compressor to verify.
Jul 21, 2013 | Ford Cars & Trucks
Solenoidvalve not open
The cooling plate is icing up, sounds like the defrost element has failed, (Fan is hitting ice, hence the noise when shutting door) if there is ice building-up in the rear of the unit, either the defrost timer or defrost element has failed, Defrost the unit for 2 days with door open and NO FOOD inside. turn the unit back on, will work fine for a few days/weeks then return to problem. Solution points to Element, timer or thermo fuse, not costly to repair any of these,. Estimate $90-$120.Any further problems. Let me know PLEASE. Russ
Jul 29, 2012 | Freezers
Talkwhy is my ge refrigerator model gss20 iepaww side by side ( freezer not staying cold enough after i defrosted it after 3 weeks my refrigerator is also luke warm. after i unplug it and defrost it works...
Hello and Welcome to FixYa!
Check for the defrost unit working... There should be a periodic defrost cycle running to melt the frosted ice. If not, then the thermostat unit along with the timer and the heaters needs to be examined. Check for the drain channel for any blockage/clog... If there is some dust on the condenser coils, vacuum the coils to remove the dust/lint else ignore that too... Carefully diagnose the tripping of the thermostat/defroster unit as it seems to be faulty.
Hope, now you got a better picture,
Best of Luck,
Concerned.
Sep 19, 2010 | GE Refrigerators
My fridge is not very cold but the freezer it fine
Check the back wall or floor of the freezer section for frost. Check the freezer( evaporator) fan to see if it is running. Check the condenser coils( under the unit ) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with BOTH DOORS WIDE OPEN to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Aug 04, 2010 | Microwave Ovens
Kenmore 596.72289200 Freezer fine, but refrigerator not coolin
you must not be getting any air flow into the refr section. make sure the fan is running and if so then you may have a defrost problem. look at the freezer section rear panel, if it has heavy frost on it then it is not defrosting properly. there are a few problems that could cause a defrost issue. defrost heater, thermostat, or timer/control board. most likely the defrost thermostat.
if it is frosted over, then shut off the unit and get ready to catch the extra water that will run onto the floor, after a full day turn it back on and if it cools, you will know that you are not defrosting. it will work ok until it frosts over again, in about 2 weeks. then you will need to find out which part is bad causing the no defrost.
Dec 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Warm Freezer and How do I set or reset the defrost mode
smoke smell coming from fridge, open back cover and a smokey cloud came out of the compressor what's going on with fridge?
Aug 17, 2007 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
