Question about Frigidaire Dryers
Started dryer ran for about 20 minutes and then cut off and will not start again. Checked breaker it was not off. Checked dryer and it has power.
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
I have had battery and alternator checked, both are good. Battery was dead, jumped car, started and ran fine. Drove 30 minutes, shut off and sat for 2 hours. Started fine again, just went to gas station...
Most likely you have a bad battery. The second option is that you have a faulty wiring and there is a constant load that takes a lot of power, but it does not make a short circuit. Check the electrical relays, maybe it's in them.
Sep 06, 2017 | Cars & Trucks
Dryer is stuck on paused and won't spin. Turned off and re-started but the motor ran for a few seconds and then went to paused again.
Good Morning Jill,
So I see that you were drying bath mats and the dryer got stuck in a "Pause" mode and even if you cancel and restart it shows "Pause" on the display. I would suggest resetting the dryer. What you will need to do is either unplug it or you can shut the power off at the circuit breaker. When you do this you will need to leave it off for at least 2-3 minutes. Cut the power back on, start any cycle. If you are still having trouble not being able to start the dryer and "Pause" showing, I suggest you either contact the manufacturer or your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Mar 25, 2014 | Electrolux Dryers
The engine on my 2000 MPV cuts out and dies when I press the accelerator. After it sits for an hour or so, I can travel for 20 min. or so before the problem starts again. HELP!
if its been a while change the fuel filter and then have the fuel pressure and volume checked.these symptoms are very common for a fuel pump problem.
Feb 07, 2012 | 2000 Mazda MPV
1998 pathfinder no power to fuel pump
The ECCSM (ECM) module may be defective.
Apr 14, 2017 | 1998 Nissan Pathfinder
The engine cut out then right away was running again then 20-30 seconds later completly cut out again. After a few minutes it started again and ran for another two days. Then it cut out again, ran for...
- When was the last time this car had a tune-up? Could be as simple as that. New spark plugs/rotor/distributor cap/condenser might do the trick.
Other causes could be:
- bad fuel pump relay (definitely first on the list of things to check, and cheapest to fix)
- clogged/old fuel filter
- bad fuel pump
Mar 01, 2011 | 1991 Honda Civic
Whirlpool electric dryer cuts out about 20 minutes into cycle and then will not start. If it is left to rest for 20 minutes it will start back up and run for 10 to 20 more minutes before cutting out. I...
its getting too hot. Take the panel off the front and take the cover off the blower wheel. It could be packed with lint. vacuum out all the lint that you can get too inside the dryer.
Nov 12, 2009 | Whirlpool GEW9250 Electric Dryer
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Whirlpool dryer stops after 5 minutes
Locate the circuit breaker for the dryer. Run the dryer for awhile and with the back of your finger pressed against each of the two switches (it will be a double breaker), see if the breaker is getting warm or wait until the dryer quits then check the breaker for any noticeable increase in temperature. With properly rated breakers, they should not get warm. If getting warm, it is a sign the breaker is bad and should be replaced.
Jun 01, 2008 | Dryers
Dryers Logo
29 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
