Question about Maytag MED5600TQ Electric Dryer
De606 will not start does nothing - Maytag MED5600TQ Electric Dryer
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
I have a Volvo Xc 70 and when I tired to start it nothing happened none of the lights come on the dashboard and when try to start it nothing turns over
If nothing at all is happening no sounds no lights nothing then I would start at the battery make sure all wires going to and from the battery are tight if there is not a tight connection it will not work proper
May 07, 2014 | Cars & Trucks
Will not start, battery is new, it just clicks and nothing. turn it off, try again and nothing, try again and it starts
Try cleaning and tightening well the battery connections along with the battery wires to the solenoid and starter motor.
Bad connections and low voltage of 12 volts can result in this anomaly.
Jun 12, 2017 | 1997 Lexus ES 300
Turn key to start and nothing no lights nothing at all and will not start not even a noise.
Your ignition barrel has failed. It is just a tube with a lot of switches in it and they fail sometimes.
May 06, 2013 | 1989 Chevrolet C3500
My 1993 nissan pathfinder wont start i get power to everything but when i turn the key nothing happends i replaced the starter and still wont start nothing happends not a sound could you please help
wire may be loose or your ignition switch could be bad hard telling if it was me id just install push button start cheap and easy to bypass all that
Dec 05, 2012 | 1993 Nissan Pathfinder
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
1995 toyota 4 runner starting problem once in awhile
Is the starter turning over the engine when it wont start or is nothing happening at all?
I might have your solution if I have more details.
If the engine is turning over but not starting then switch on the ignition and push it to start.If it starts you probably need a new ignition switch.
Please get back to me .Thanks
Aug 04, 2009 | 1998 Toyota Corolla
I need a schematic for a Maytag Elec Dryer HDE606
Man I been digging around in the shop for my copy of a DE606 manual I have to no avail. hell I might have even thrown it away.
Well you have a common wire, a start wire,a run wire and 2 larger wires which carry the heater load. go with the 2 larger wires on those terminals for the cent switch. White would be common so that leaves 2 to guess at seems to me those might match number for number. Just guessing cause I ain't worked on one of these halo of heat models in years.
Jan 13, 2009 | Maytag Dryers
Maytag MED5600TQ Electric Dryer Logo
321 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
