Question about Harman Kardon Car Audio & Video
My 2000 z3 roadster Harman Kardon spaeaker/subwoofer is not working properly... how do you access to check/replace this speaker?
Open SKy
  • 620 Answers
SOURCE: harman kardon
Orastie
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Carl
Posted on Dec 30, 2007
Open SKy
  • 620 Answers
SOURCE: Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Posted on Jan 23, 2008
SirHanz
  • 145 Answers
SOURCE: subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Posted on Jan 29, 2008
SOURCE: Harman kardon HK595
I'm not sure of anywhere online, but I actually have a spare set of the satellite speakers sitting at my house, from a unit I had previously (the sub went out). I can make sure they work and get them to you if you'd like, email me at drkstr (at) gmail (dot) com...
But I have only one spare...
I'm not sure about wherever else you can buy them online. I was actually lookin to buy another set when I stumbled on this thread, but they're kinda hard to find lol. The whole unit used to be $30 for a refurb'd model, but those places are out-of-stock currently.
Posted on Jan 05, 2009
SOURCE: taking apart harman/kardon subwoofer
turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
Posted on Dec 11, 2009
Why doesn't subwoofer work?
Your nose and eyes should lead you to the faulty part for this, once you get inside the subwoofer. Anything that burns up producing the smell will possibly leave a visual trace. But your nose will lead to the part that smells. Replace it and see what happens!
Nov 26, 2015 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Harman Kardon Soundsticks II with subwoofer
Check you volume control center and the likes it may have turned off by itself
Dec 24, 2013 | Harmon Kardon Harman Kardon Soundsticks...
My MacBook's audio still on even when harman Kardon speakers are connected to the computer.(Original version with USC connectors).
As I seem to recall the very first version was powered by the computer and as such may not be compatible with your Mac. I may be thinking of Apple's Clear speakers though? Do your HK Soundsticks have a power adapter or AC cord?
Oct 15, 2013 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Harman kardon hkts7 subwoofer problems
check the audio stage and replace the audio stage ics
u 201,202,301. with TL074 ic
Mar 24, 2013 | Harman Kardon HKTS 7 System
Harman Kardon SoundSticks II Computer Speakers
Hello
It seems that the power supply section of your speaker systen has the fault. Check the fuse inside it. If it found blown out, never replace an other fuse in place. Check the power supply circuit board for any short circuited components in it, before replacing an other fuse.
Mar 21, 2012 | Harman Kardon SoundSticks II Computer...
Do i need a satellite cord for this harman kardon to work properly
You shouldnt need a satellite cord. If the HK 12 has parallel L and R inputs and outputs, you should be able to run sound into the sub, and then out to whatever speakers you have. Assuming they are not a part of a sound system, and you are running 2.1 stereo.
Mar 19, 2011 | Harman Kardon HKSUB 12 Subwoofer
Harman kardon HK595
Oct 12, 2008 | Harman Kardon HK595 Computer Speakers
I have Harman Kardon speakers and subwoofers connected to a Denon AVr 1508 receiver. All my five speakers are working but my subwoofer doesnt work. I m pretty sure I have connected the subwoofer properly...
There is a setting under your speaker setup to turn the subwoofer on. If speakers are set to small it auto matically sets the subwoofer to ON. If the speakers are set to large it turns the subwoofer off but you can manually adjust.
May 02, 2008 | Denon AVR-1506 Receiver
Subwoofer - no sound
Had the same problem when mine first arrived. Unplug and replug the power cord at the back of the woofer. Worked for me!
May 16, 2007 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Car Audio & Video Logo
111 people viewed this question
Top Harman Kardon Car Audio & Video Experts
xxxxxx xxx
Are you a Harman Kardon Car Audio and Video Expert? Answer questions, earn points and help others
