Question about Dryers
I have an admiral dryer that will turn on but doesn't shutoff and overheats, we are concerned it may catch on fire, what could be causing this?
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
NATURAL GAS TO LP FOR ADMIRAL 6.5 #AGD4675YQ
Propane burns hotter than Nat Gas, so it needs a smaller orifice, and less combustion air. Don't do it yourself, get your LP company to come out and do it, and sign off with a sticker that they converted it, in case it ever catches on fire, you will be absolved of all litigious liablitity.
Feb 04, 2013 | Dryers
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Door Switch
Wiring
Admiral Dryer clicking noise
check fan cage can wear and need adjusting
May 30, 2012 | Admiral Dryers
I was cleaning the lint filter and placing the debirs in an empty oatmeal box, suddenly the top flew down the dryer vent shoot. I could not retrieve it. What can I do?
Disconnect your vent hose from the dryer and remove the top of the box.
You may have to disconnect it from both ends to get it out if it is in the hose, do not leave it in there as it could cause the dryer to overheat and catch on fire.
If it is still in the machine then remove the back of the dryer and locate the blower, remove the blower and it should be there.
You can turn the dryer on momentarly then right back off to **** the paper lid to the blower.
This is a Free answer, Please rate me
Oct 02, 2010 | Estate TEDX640JQ Electric Dryer
Burned metal screen on the back wall of dryer
What u have is a fire hazzard. U have a hi temp limit switch stuck on and if not repaired it will catch fire
Nov 20, 2009 | Amana Dryers
Admiral capacity plus dryer is not heating up - it seams to through a little heat for a couple of minutes then it is cool - i tried this on the auto setting and on the "straight" minutes setting.
check your vents and lint trap. there is an overheat sensor that will cut out power to your element. also there is an overheat fuse which may blow (cheap and easy to replace) but there would be no heat at all and in some models the dryer won't even turn on it it blows. so this is not likely
Aug 16, 2009 | Dryers
A5 grooming shear overheats
Usually a faulty electrical component breaking down.The insulation factor is deteriorating due to an electrical short in the component. Prolonged use will eventually shorten the 15 minutes and have it catch fire while in use. Get it fixed or ditch it before you get burned, electrocuted or it causes house fire
Jul 25, 2009 | Hand Tools
My admiral dryer LNC7753A71 just stopped working. Turning the timer only produces a clicking noise but all else appears dead. I checked the 240V outlet and its producing 240V and 120V on each side. The...
Your dryer is equipped with a thermal fuse located behind the drum seat on the heating coil.
http://www.applianceaid.com/la-1053.html
There are two white wires connected to the fuse. Pull those off and connect together. Your door light will come on if that is your problem. There might have been a problem that caused the fuse to blow. Check for kinked dryer hoses, dirty lint traps or anything that might have caused it to overheat. You must replace the fuse or you risk catching the dryer on fire.
May 05, 2008 | Dryers
Dryers Logo
Top Dryers Experts
