Question about Philips 42PFL5332D 42 in. LCD Television
My tv made a loud popping noise, now it will not come on. it seems to power up but has no picture and no sound, where do I start to fix it
  • Philips Master
  • 8,457 Answers
This problems,it the Tuner board is dead.That the board,that take in the incomming broscating signal cable plug in.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Sep 08, 2010
Samsung plazma tv will not turn on, makes loud popping noise when it tries. It started this several days ago but when it did go on the picture was fine. Can this be fixed at home?
Do you have electronic test gear and the knowledge required to diagnose these types of products?? Can it be fixed is a very broad question. If the answer is no sure or no then have it repaired (expensive) or replace the TV.
Dec 29, 2016 | Samsung Televison & Video
Samsung tv made loud noise and will not power up
Sounds like capacitor exploded. Check power supply area. Flat panel tv's use cheap capacitors. Most likely this capacitor is in the power supply area. The top will be popped, they're made to pop when they go bad. Have professional fix it.
Feb 14, 2014 | Samsung Televison & Video
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
TV LG Model 50PX1D-UC Flat Panel Television Loud Popping Noise. TV goes out. I turned on my tv the other morning and it let out a loud popping noise and the picture went out. Any suggestions...
The problem is that there is a bad capacitor inside the unit, it is either on the main panel or the power panel. The popping sound you got was due to the fact that the lead on the capacitor was bridging, therefore causing some electrical popping sound.
Run a check on the main panel and the power panel for any bad capacitor and replace it with a new one. That way, your television will be in good condition once again.
Take care and good luck
Jan 02, 2011 | LG 50PX1D 50 in. Plasma Television
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
LG plasma tv made loud popping noise
The plasma gas tubes may be damaged or the gas couldve leak out. remember plasma have to remain upright at all times even when transporting them, if they are not you should just set it up straight for about 3-4 hours before turning it on.
Apr 23, 2009 | LG 50PX5D 50 in. Plasma HDTV
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Loud cracking noise sounds like fireworks and wont get a picture
It seems you have loose or cold solder joint connection problem,causing a cracking sound.The solution is to reworks or resolder the solder joint connection in power supply section, audio section and inverter section...
Hope this may help you;
Regards,
VOTIT
Sep 25, 2008 | LG RZ-37LZ30 37 in. LCD Television
Philips 42PFL5332D 42 in. LCD Television Logo
235 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
