Question about Lectrosonics FENDER PD-250 PASSPORT SYSTEM + 1 SHURE HANDHELD&1 LAVALIER WIRELESS SYSTEM / Microphone
I have the passport p-250 i left it on over night and when you turn it on the red comes on that said protect thanks jimmy
  • 3 Answers
One or more of the power transistors are shorted. There are eight transistors in the amplifier section - 2 high & 2 low for each channel. This unit is difficult to open up to work on.
Unplug unit and check speakers with a multimeter to make sure they are not shorted.
Take off front panel (8 screws).
Remove power supply shield with yellow tape (2 screws).
Remove 2 screws holding top of power supply, loosen bottom screws.
Replace front and hold in place with a couple screws.
Turn unit around.
Remove screws holding heatsink (6 screws)
Open rear storage door.
Carefully pull amp section out, being careful of tightly routed wires. Note any connectors you disconnect.
The amplifier is the board on the top, the power supply is in the silver box.
Push the power supply forward and loose the black screws holding the amplifier board bracket closest to the heatsink.
Loosen the top brass screws holding bracket to heatsink and remove the bottom screws.
Remove all eight of the screws holding the transistor brackets & transistors to the heatsink. Look and take careful note of how the plastic insulators weave through the transistors. If you get this wrong, you can short out the whole amplifier when you turn it on.
Slide the amplifier board down and out where you can get to the bottom. Note the wires and connectors going to the small protect board over the amplifier.
Check the transistors with a multimeter to find the shorted ones. Remove and replace bad transistors. These are connected in pairs.
Reassemble in reverse. Be careful of reconnecting wires and insulators. Don't test until the amplifier PCB is back in place and you're sure of all wires. If the PCB is touching the power supply, you'll short it out.
Good luck, I told you this wouldn't be easy!
Posted on Jun 09, 2011
I need an emergency passport today
I thought I left you message on this. There are companies that will expedite passport application. Just look on the internet. These companies charge more but they could get you passport in 24 hrs. stewbison
Aug 16, 2011 | Optics
My passport 250 goes into protect mode on occasion. The other night at a gig it would clip into protect as soon as I sent a signal from the mic or guitar. It works fine at home. Is the unit sensitive to...
These seem to be tempermental. I would look for radio frequency interference from nearby transmitter leaking into your guitar cable or mic cable that puts this on the ragged edge of feedback. DO NOT boost highs with the EQ... You can get supersonic feedback that you can't hear, but puts the amp into limiting. Any audio input can start the feedback. These amps are VERY hard to work on due to the packaging. A lot of people have smoked their units and then require repairing.
May 24, 2011 | Fender Pd250 Passport Deluxe 250watt...
We were running a small show on the system, it was not loud. Throughout the night the protect button came on, but then we made some adjustments and restarted the system. Then it went into protect mode and...
Yes, take it to a repair shop.
You have a failure either in the power supply or one of the power amps. There is likely to be burned component(s) that are not user serviceable.
These things are a bear to work on... Mine failed again and I dread having to work on it.
The protect monitors power supply current drain of the switcher and the power amp balance.
DO NOT USE IT till it is repaired. Continued use or fuse replacement will likely do additional damage.
Apr 29, 2010 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
Amp goes into protect mode as soon as switch is turned on. Pasport 250
There is a problem with the internal amp itself. These are extremely difficult to access. Contact Fender for a local authorized service center.
Dan
Mar 11, 2010 | Fender Passport Deluxe 500watt Sound...
Fender Passport 250:
The manual is here if you don't have one:http://www.fender.com/support/manuals/pdfs/manuals_elec/fenderaudio/PassportP250.pdf Have a look at page 9 and read the VIP Channel 1 only section. It will explain the solution to your problem and the settings to overcome it. Please let me know if this helps.
Nov 29, 2009 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
Fender Passport P-250
Sorry about the delayed response, I just noticed this posting.
The protect indicates a problem with the output section of the amplifier. Effectively the amp has been shutdown to prevent further damage. Although the unit should not have been working (at least not well) at 30V, unless they htried to run it at full volume, there should not have been damage. The outputs are blown and this unit requires repair. If I remember these units correctly, there are 8 output transistors, most of which may require changing. WIthout seeing the unit and taking some measurements, I can not say for sure, but expect $40-$70 in parts.
Dan
Sep 03, 2008 | Fender Passport P-51 Consumer Microphone
Sentry 3100 safe_i remember combination but do not remember which way to turn
go around 3 times to the left
stop at the 1st number
go to the left one full time and pass the # but stop at the 2nd #
go to the right and stop at the 3rd # the 1st time you come to it
I just bought one last night
Jan 15, 2008 | Sentry Fireproof Safe
143 people viewed this question
Top Lectrosonics Audio Players & Recorders Experts
Michial Gueffroy
Karl Luedemann
Gerhardus Stroebel
Are you a Lectrosonics Audio Player and Recorder Expert? Answer questions, earn points and help others
