Question about Whirlpool Refrigerators
My Whirlpool Conquest Mod # ED5LTAXVL00 Will not self defrost. I have to remove the back cover from the freezer side and defrost it manually.
4 Suggested Answers
  • 61 Answers
SOURCE: freezer issues with Conquest
freezer is supposed to defrost? need more info..
if you need a part try www.appliancepartssolutions.com
Posted on Jan 16, 2010
SOURCE: Whirlpool conquest sibe by side GS6SHAXKQ01
I have whirlpool conquest model GS6SHAXKQ01 - Came home to puddle of water, everything in freezer is melting, frig is getting warm. Lights come on both sides...Suggestions? Thanks
Posted on Feb 09, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: model # GS5SVAXAOO. My freezer
Sorry to read about your problem. you can have many different problems.
if your freezer, the side where you freeze meat, is defrosting and ice melting, your Refrigerator, where you keep the eggs will soon follow. your freezer supply's the cold to refrigerator.
you are having a complete failure, and below is a list of what may be going on.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company since you do not have the equipment to work on a defective compressor, if that's the problem.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Testimonial: "very well put"
I had water in bottom of kenmore fridge. This is now fixed but soon after I had frost building up on back wall of freezer.
you now have a defrost issue,remove rear panel inside freezer if the evaporator is covered with a heavy ice and frost build-up then either the defrost heater under the evaporator coil is open or the defrost thermostat on top of the coil is bad you need to check both for continuity or the defrost timer if equipped or the A.D.C. adaptive defrost control is bad and not supplying power to the defrost circuit
May 02, 2012 | Kenmore Top Freezer Refrigerator
I want to replace faulty freezer thermostat in whirlpool side by side fridge mod ed22dqxew01 --am having trouble removing cover for freezer-refridgerator control dials. I removed two screws in rear of
First question why are you replacing the freezer thermostat? Do you have an ice build up on the rear wall of the freezer? This build up if you do have it is not due to the thermostat control for the freezer. It is termed as a defrost issue due to a fault condition being present in the defrost thermostat, the defrost heater, or the defrost timer or adaptive control depending on which type of refrigerator you have. I will await your reply as to why you are replacing the control thermostat and if you do have any ice up condition before posting further how to solve this situation. I await your reply
Thank you
Rick
Jan 01, 2012 | Refrigerators
Whirlpool gold conquest, freezer working fine, fridge warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 05, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I get a small puddle of water in front of frig, about once every 2 or 3 weeks
THe defrost siphon tube in freezer is partly blocked. Turn off fridge, remove cover of condenser and check the drain tube for blockage.
Nov 08, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer issues with Conquest
Jan 16, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Freezer is not working
Check the inside, back lower wall inside the freezer. If there is ice built up on it, you have a defrost problem. if so the heater is most likely bad and will need to be replaced. You can take a blow dryer and defrost the ice, removing the panel so you can defrost behind it also. Once you have, you can see the heater and at that time you can get to it to check it and see if it's bad. You can put the panel back on and turn the fridge back on and it will work right for 3 to 4 days. This will give you time to either repair it or have it repaired without loosing any food. Good luck
Dec 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool conquest sibe by side GS6SHAXKQ01 freezer has defrosted and food is thawed
Sep 29, 2009 | Whirlpool GS6NBEXR Side by Side...
WHIRLPOOL GD25DIXHWOO NOT COOLING
the defrost system may be hung up in defrost try locating and replacing the timer
http://www.whirlpool.com/custserv/index.jsp
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool conquest side by side 2003 model
facing the back of the frige there is a cardboard or metal panel across the bottom that covers the compressor. remove panel, on left side of compressor is the main control for the frig. there is a short in that board that causes this problem. youll need to replace te board
Nov 20, 2007 | Refrigerators
Refrigerators Logo
143 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
