Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
I have a bosch 500 bexxt series washer and the front plastic insert on the door has come loose. It seems to have plastic male pine that look they should snap into the door but the top three are loose/out. How do I get this insert back in? The pins don't look broken,
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
I think if you can remove the cover and than re-install it may remedy the problem.
Try this...With the aid of a small screw driver, knitting needle, or anything small enough to fit in the small hole in this cover...
It will push in a tab, it doesn't take much force.
Rotate the hole (clockwise) to 6'oclock and it should come free, the edges of the cabinet, not the cover, are very sharp so be careful.
Now with it off you can observe the notches and how they should line up, place it back in place and turn it counter-clockwise.
If nothing is broken on the plastic cover it should resemble this...
Let me know how you make out or if you have any problem.
Thank you for choosing FixYa and Good luck.
Regards,
Macmarkus :)
Posted on Sep 08, 2010
  • Mark MacDonald
    Mark MacDonald Sep 08, 2010
    Hello again.
    I think I may have misunderstood the problem you are having, as is probably obvious now, sorry.
    Upon reviewing your post I think you meant the main door, correct ?
    If so it is unfortunately a non serviceable part, aside from the complete door...
    i.e.
    It`s about $250us. so if yours isn`t too bad you may want to live with it as long as possible...as long as it isn`t leaking of course.
    Let me know if or how I can assist you further. Again sorry about my first reply.
    Regards,
    Macmarkus :)
I have a bosch nexxt 500 series washer. When closed it clicks 3 times in series for 3 cycles and then displays e 01. I replaced the lock mechanism with a part directly from bosch and still the same
An answer found on a BOSCH support site said:
"the E:01 indicates a door lock error, make sure the door is closing tightly, you also may have a loose connection on either the door latch assembly or the control board, if these check out replace the latch assembly."
Since you've already replaced the mechanism then it seems possible a loose -connection- may be your problem. If you've already checked all this, please post back.
Jul 08, 2015 | Bosch Washing Machines
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Oct 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Door will not open bosch nexxt 500 series
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more with some luck.
The door typically locks as a result of the unit failing to drain, so....
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
**NOTE - you should also see a ring attached, if you pull this the door should unlatch, but getting the water out first if present is usually a good plan
Once the door is open and you've removed the items you wanted. Unplug the washer for 20minutes or so and then plug it in again, to see if the control "resets".
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Apr 15, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Error code 13 on my 5oo plus series washer, it will not coplete the load or unlock the door, im afraid the clothes are going to start smelling
On the small round disk at the bottom right...insert a small round pointed object into the hole and push gently, while do this rotate the disk clockwise. This will allow you to remove the disk. Look inside and there will be a slender plastic rod next to the drain clean out. Pull down gently to manually unlock the washer door. Unfortunately that will unlock the door but probably not fix what caused the issue in the first place.
Jan 18, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
How do you clean the drain in a bosch next 800 series washer?
Almost all Bosch machines have a manual drain trap that usually can be accessed from a small door in the front panel. Open the door and you will see the trap access.
Jun 05, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
It washes, then stops in rince cycle & the door is locked and won't open no matter what setting I change it to.
try opening cover lower right (six circle, use small wire,or nail in hole move one way or another. white plastic hanging down pull on it push in on door this will unlock it. un screw black cover and clean out pump Watch out for water on floor no good way to content. Maybe wet vac. Found pet hair pine needle etc. blocking pump.
Apr 27, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch 500 series Front Load Washer Door hanging a bit lower than when purchased
Even if you do not realise it most people lean on the door as they open it, to rectify with the door open but almost in the closed position lift the door by pulling up on the door catch end, this will straiten the hinge, very common problem Regards Engineer
Jul 26, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
226 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
