Question about Foxconn P4M800P7MA-RS2 Motherboard
Please help me in my RAM
I need your help.....
I have a foxconn motherboard (P4M800p7MA-RS2), it supports both DDR 400 (two slot) and DDR2 533(two slot).
When i bought my PC, I installed a 256MB DDR 400. This time I changed it with 512MB DDR2 533. When I installed the DDR2, I removed the DDR1 because the manual told me me to do so. I installed it correctly on its respective slot.
Sadly, my PC hangs everytime I log on.
I'm so confused because the manual said that "it supports DDR 400 and DDR2 533" memory.
I'm using a (1) 256MB DDR 400 this time. Please help me, I want to use the 512MB DDR2.
cpu name: Intel(R) Pentium(R) CPU 3.06GHz
motherboard model: P4M800p7MA-RS2H
BIOS Name: Phoenix- Award V6.00PG
memory device: KVR400X64C3A / 256Mb
OS:WindowsXp+SP2
  • 1 more comment
  • hope13 May 16, 2008
    Sir, thanks a lot...
    First I used a (1) 256MB DDR 400. But i tried to changed it to a (1) 512MB DDR2 533.
    oh yes, they are individual stick.
    Yes i installed it correctly. I remove the 256MB DDR 400 from the blue slot and put the 512MB DDR2 to the yellow slot.
    I logged on, sadly as it reaches to the "windows starting up (blue screen)", my pc hangs there. So i brought another 512MB DDR2, sadly it shows same response like the first one... I tried to put the two 512MB DDR2 at the same time on the yellow slot, sadly, again, same response occur.
    Please help me sir, I want to use the (2) 512MB DDR2.
    OS:WindowsXp+SP2
  • shoaks Nov 20, 2008
    I am having a problem with new Kingston Memory that I just installed on my PC. The motherboard that I have is a P4M800P7MA-RS2 Motherboard and the I had 1 512MB (DDR2 533MHz) memory moule in the 1 slot. I then installed a 2GB (DDR2 533Mhz) and my system only picks up 1.5GB when both memory modules are installed. When I removed the 512MB it still only picks up 1.5GB total memory installed.
    I have also checked the spec on the mother board and it show that it can support up to 2GB's.
    What could be causing this to happen?
    PLEASE HELP????
    Shoaks
  • Rich Travis May 11, 2010
    From your description I'm not clear on some things.
    first, while you provided the part number for the 256MB Ram, you did not provide the part number for the 512MB. Do you have that available? It appears that there are some 533 module that have problems.
    secondly, I want to be clear: when you said "I installed it correctly on its
    respective slot" are you saying that you only installed the 512MB module? According to the manufacturer you can't mix 400 & 533 memory (this isn't always true, but it sometimes is). And, if you have both Yellow & Blue slots, which?
    Thirdly, when you refer to "a 256MB DDR 400" are you talking about 1 individual stick or a matched pair? I'm pretty sure I know the answer to this one, but I thought I would check.
    President:
  • 2,351 Answers
Hi hope13,
you had it correct the first time. The DDR2 533MHz memory should be in the Blue slots. When using two DIMMS the motherboard requires the DDR2 533MHz memory be of the same size, brand & speed. For you to get a blue screen has nothing to do with you're memory. If there was a problem with you're memory, you bios would let you know by beeping a series of repeating beeps. Blue screens are usually caused by software & some hardware like you're hard drive. If you have data on you're hard drive & you do not want to erase it by re-installing windows fresh (That includes a must format), than I can suggest you download this software from this site. Click on the link.
http://www.ultimatebootcd.com/ Read what the software can do for you. If you do not want the software. Than break out you're windows CD & load it into you're CD-ROM drive. Boot the PC to the CD-ROM drive & in-stall windows. You're PC will function again when you finish installing windows & you're motherboard driver cd.
Good Luck!
I would have posted sooner but I though another was answering you're question.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 22, 2008
What ramm do i need and how much can i put in
You may use either DDR 400 or DDR2 533 RAM. These will be 184 or 240 pin chips, respectively. The maximum RAM for this motherboard is 2GB total, and you may only use one type of RAM; you are not able to combine different speeds of RAM.
May 07, 2011 | Foxconn P4M800P7MA-RS2 Motherboard
Only half of the RAM is active
HI,
Well, you need to understand that The first 2 slots on the board supports DDR2 and the last 2 supports DDR, so first off make sure that your using the first two slots. With that said, I assume that the Ram are identical? If not, that can be problematic. The next thing I would check is the bUS speed, and check with the mfg to make sure they are compatible modules. It supports DDR 333/400 and DDR2 533/400
As well as supports 128/256/512/1024 Mb technology up to 2GB. If your memory falls within these specifications, then put one chip on at a time to test to make sure that each one works independently, as well as try each slot independently. , If both work that's a good thing. You also need to update your BIOS which you can do HERE. If you've checked your slots and each memory stick, and you've updated BIOS, they should work. If not, they there is something wrong with the board when two chips are inserted, your connector between the two slots must be damaged. However, most unlikely, If you follow the above suggestion, you should be OK.
Good Luck,
Mark
Dec 29, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Problem With ddr2 (Upgrade From ddr 512mb 400 to ddr2 1gb 800)
If it works fine with one stick of ram. Then it is the ram that is incompatible. You can try different settings but you may end up that the stick isn't compatible. Hope this helps let me know if you have any other questions.
Thank you,
Lee
Nov 05, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
DDR2 RAM ENQUIRY
Dear Sir
*********** Board is :Foxconn P4M800P7MA-RS2
Max Supported RAM : 2GB DDR2
Supported RAM speed: 533 MHz • 400 MHz • 333 MHz • 266 MHz. I think it deffinately solves your problem.If you have any problem post your comment with more information.
Good luck
thank you for choosing Fixya
MPN P4M800P7MA-RS2
Supported RAM speeds 533 MHz • 400 MHz • 333 MHz • 266 MHz
Aug 20, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
I need to solvthe problem of my new install memory
According to the specs of this motherboard, it supports DDR 333/400 and DDR2 533/400 memory modules. It does not support DDR2 667 memory modules.
DDR 333/400 memory modules can be installed in the yellow slots, whereas DDR2 533/400 memory modules can be installed in the blue slots.
Only one type of memory modules (either DDR or DDR2) can be used. Mixing of different types of memory modules is not supported.
Jul 11, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Can i upgrade RAM from 533MHZ to 667MHZ for P4M800P7MA?
Please try to upgrade your BIOS, it may solve the issue.
Jan 14, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
MEMORY UPGRADE FROM DDR 256Mb to DDR2 1GB hangs when Log on/Booting
Its a memory problem obviously. Try dusting the memory slot and try inserting the memory into the slot a couple of times. If still not working, the memory may be incompatible(rarely, there are brands of boards that doesn't suit to certain brands of memory), or it may be damaged.
Sep 27, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
If your PC boots up successfully and load windows then its mean that RAM is working fine... There is some problem with OS settings.. So at XP booting press F8 for start-up menu and select Last known good configuration... Hope it will work...
Please Rate .... Thanks.
May 14, 2008 | Intel Motherboard
Ddr2 ignored
the size of the ram is not enough, try increase the size of the ram.
uzowuanya
e-mail: uzowuanya@yahoo.ca
Feb 12, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Foxconn P4M800P7MA-RS2 Motherboard Logo
383 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
