Question about Singer 3116 Simple
The under thread won't come up. - Singer 3116 Simple
    Genius:
  • 1,788 Answers
You have to hold your top thead and turn your handwheel towards you. Make sure that your bobbin thread has a tail of 3-4 inches so that the top thread can hook the bobbin thread, also make sure that your needle is inserted with the flat side facing the rear of the machine and that your bobbin is placed with the thread unwinding the right way. Good luck, anymore problems call singer at1-800-4singer
Posted on Sep 12, 2010
My rs200 toyota sewing machine bobbin won,t take thread round to lift bobbin thread
At 8 months old must still be under warranty, so take it back before you have any more problems and get a replacement.
Jan 19, 2015 | Toyota Sewing Machines
Babylock Esante stopped. Just makes loud noise but won't move even manually.
You probably have a jam. Start digging under the bobbin area.
If you get it all cleaned up under there... and it still won't move. Time for service by a pro. Could be something horrid like a bent shaft.
Good luck
Nov 03, 2012 | Baby Lock Sewing Machines
PE-3000S Pacesetter won't pick up bottom thread
try changing the needle
also rethread the machine
clean under the needle plate & in the bobbin area for loose threads or lint
if these suggestions don't help the it's possible that the machine has jumped time & needs to be serviced
May 15, 2012 | Brother Sewing Machines
I am trying to thread the bobbin case on my machine.but everytime i do the needle won't pick up the thread.i have a singer slant 404.the diagram isn't very helpful.
if you can't find the spring, then it might be missing. take it to a sewing machine repair shop to find out if it's missing
Jan 17, 2012 | Singer Sewing Machines
When sewing, the thread keeps pulling the fabric threads and the result looks messy. I've tried playing with the thread tension but it won't help.
have you tried using a new needle- if the needle is the slightest bet bent or or damaged it can cause problem with the fabric threads
if the needle is not the correct one for the fabric, it can move or damage the fabric threads
also clean under the needle plate for loose threads or lint also in the bobbin area
Aug 29, 2011 | Brother CS6000i Computerized Sewing...
Needle won"t stay threaded
that use to happen to me on my sewing machines, I would rethread the machine to make sure the thread is not caught on anything like the thread spool, or around anyone of the thread guides
also for both top & bottom threads, I keep a thread tail of 3 to 6 inches & before I start sewing I pull the thread behind the needle to the back of the machine & the I put the fabric under the foot & start sewing & now I don't have that problem anymore
Aug 24, 2011 | Singer 3116 Simple
I am having a problem with my Janome Decor Excel 5018. It was working fine, until the bobbin thread won't gather with the top thread. And the top thread is binding up underneath the fabric. Kim
try a new needle
rethread the machine top & bobbin, that way you make sure the thread is not caught anywhere
make sure the bobbin is correctly inserted in the machine
clean under the needle plate & in the bobbin area for loose thread & lint
always keep a long thread tail of 3 to 5 inches long, & keep the tails pulled back behind the needle
before sewing
if none of these things help the problem,, then it may need to be serviced
Aug 10, 2011 | Janome D'cor Excel 5018
When I turn the knob to move the needle to catch the bobbin thread, it hits something underneath and won't keep going down. The same thing happens when I turn the knob in either direction. It's...
Have you removed the bobbin case to clean it? If so, it probably needs to be reseated. Remove the bobbin. Take out the case and reinsert it. If you can't get the bobbin out easily, there is probably thread clotted up somewhere under the feed dogs. I usually gently rock the handwheel back and forth as I brush the bobbin case area to begin dislodging the "clot." It also helps to remove the throat plate so you have a better view of the mechanics under the feed dogs. You'd be surprised at all the goop that can be caught but you can't see. If you do find a thread clot, use a machine brush and tweezer to gently remove each thread bit. I really hope this helps you. If it does, please come back to Fixya and rate my advice. Thanks!
Aug 01, 2011 | Brother CS6000i Computerized Sewing...
I have a E20 Huskystar I was sewing elastic, the machine pulled to many threads into the bobbin case. I pulled out the threads and the thread take up doesn't work now. The machine gets hung up at the...
Thread in the bobbin area can be difficult to get out. Even though you do not see any there is thread wrapped around under the hook area. Shine a flashlight in there and look carefully. Often times you will see a piece of thread. Use tweezers to get it out, pull slowly while turning the wheel by hand. If you notice the thread not coming out, turn the wheel in the opposite direction.
Removing parts in the bobbin area will allow you to get at any thread that is hung up in there. The smallest of pieces can create havoc in there as you may find out. Before removing parts make sure you have a manual in case you forget how to put them back. Remove one piece at time and check for thread right after. No need to remove more than you have to.
Jul 07, 2017 | Husqvarna Viking 1
Singer 3116 Simple Logo
37 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
