Question about Weather King 10AJA2501AH Air Conditioner
Buzzing and then no cold air
My Weather King AC unit buzzes but the fan does not come on. I manually started the blades spinning and they spun strong after that. Unfortunately, the fan is not producing cold air and my house is 90 degrees when I go to sleep. Someone please help! I can see a dead snake in the corner where the motor is but I'm not sure if that means anything. Thanks in advance
  • Anonymous May 18, 2008
    no cool air
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Checkout koolbreezeshadiagnostic.smrated.com.
Posted on Jun 02, 2008
To me it sounds like the start capacitor is bad on the unit that starts the fan,thats why when you spin it ,it starts and the compressor which has a hermetic motor in it and sealed which may be bad as well but a tech must come to make some readings on the outside of the compressor where there are terminals on them.
Posted on May 24, 2008
  • 828 Answers
You need a service tech to check out your system. Your compressor may not be starting which could be the reason for the humming noise and no cold air. Dead snake may not be related to your problem.
Posted on May 22, 2008
My Lennox ac is making a very loud buzzing sound and the fan blades are not turning. We replaced the dual capacitor and that seemed to fix the problem for a couple of days, now it's doing the same...
Fan motor is probably bad, if it is under 5 years old the parts are under warranty. Do not run the unit for very long without the fan working as it can damage the compressor.
Aug 23, 2011 | Heating & Cooling
Outside unit not operating. Outdoor Unit fan (fan
the fan motor is burt. replace it. it will still spin if you manually engage but it will overheat an may even cause fire, also that waste tremendous amount of electricity now.cap is not defective,
Jul 04, 2009 | Heating & Cooling
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
Carrier AC 38CKC019 may have overheated. The fan unit buzzes but does not turn.
Hey there, ok, now if the fan is spinning and the compressor is buzzing, the compressor is locked up and needs to be replaced. If neither is running and the buzzing is coming from the control panel on the unit, it could be the contactor. Also there is a chance that the fan motor burned up, causing the compressor to fail so the fan would be off but the compressor is buzzing and locked up. If nothing is running also check the circuit breaker it could just be he conactor you are hearing. At that point you need to figure out why the breaker tripped. Let me know what you find out
seth
Jun 25, 2009 | Carrier 38CKC018 Air Conditioner
Toutside a/c unit fan quit spinning
sounds like starter on a/c is going out you need to replace it as it starts the fan and compressor as well good luck (thats assuming toutside means outside)
Aug 23, 2008 | Heating & Cooling
Fan
you need to have whole ac serviced do everthing at once so it works right
Jun 02, 2008 | Weather King 10AJA4801AH Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King 10AJA2501AH Air Conditioner Logo
324 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
