Question about Iomega 33089 250 GB Hard Drive
External drive wont mount
My old G3 MAC running OS 10.3.9 crashed and now wont mount my Iomega USB External Storage Drive. It appears in "About This Mac" but says: Iomega HDD USB 2.0 Drive:
  Capacity:    232.89 GB   Removable Media:    No   Detachable Drive:    Yes   BSD Name:    disk1   OS9 Drivers:    Yes   Product ID:    126 ($7e)   Vendor Name:    Iomega   Speed:    Up to 12 Mb/sec   Bus Power (mA):    500   Serial Number:    03000B1AE6C6
IOMEGADrive:  Capacity:    232.76 GB   Writable:    Yes   File System:    Journaled HFS+   BSD Name:    disk1s10   Mount Point:
If I start up in OS 9 the drive shows up and I can access and open files. There was a file in the OS 9 trash called rescued items from Iomega.
I attached the drive to a G4 I have and it has the same problem except the real Iomega drive icon is used in the in the "About this Mac" USB list instead of a plain gray drive icon.
Any help would be appreciated.
Janet
  • alfielewis Mar 12, 2009
    my iomega minimax drive isnt mounting now following my macbookpro crashing during a back-up. disk utilities sees the hard drive but returns errors when verifying or trying to repair it. mount command in disk utilities does not make it mount either
  • Anonymous Mar 29, 2014
    i had a iomega drive attached to my router with a sony vaio. i recently changed to a macbook and it cannot be accessed now. what could be wrong?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
You can use the Disk utility in MAC to run the diags on your drive.
Good Luck.
Live, Love, Laugh.
Posted on May 14, 2008
I have windows 10 and it does not see the USB zip drive. Is there a driver for win 10 to operatr the zip drive
you could use a hbcd boot disk or a live boot disk and install the ziip drive temp. this way you could recover data. Their is always a workaround. Good Luck.
Nov 03, 2015 | Iomega ZIP 100 MB USB (32133) External ZIP...
My system doesn;t boot up and I don't have the CD to boot up my system. When I brought the powerbook G3 it didn't with the CD. Please where can I get it from? I am in Ghana now. Thanks Ishmael
If you have another Macintosh that is working correctly, you can copy the contents of that hard-drive, including the Operating System onto an external hard drive.
To do this, install Carbon Copy Cloner on the working machine and plug in an external hard-drive. Then run Carbon copy cloner and make the source the computer's hard drive most likely named "Macintosh HD". Then choose to have your external hard drive be the drive where all of the data is copied. Then run the program and let it copy all of the files.
Once this is done, remove the external drive from the computer and plug it into your G3. Turn on your G3 while holding the Option (alt) key and then double click on the hard-drive image that is named whatever your external hard-drive is named.
Once your system boots up from the external hard drive, run Carbon Copy Cloner again and repeat the process again except have the source be your external drive and have the internal drive in your G3 be the disk that has all the data copied to it. Once this is done, turn off your computer, remove the external drive, and then boot up your computer again.
You will have an exact clone of the computer that you copied the data from and will just simply need to adjust the account settings as such as you see fit.
The external drive process can be skipped if you have a firewire cable. Simply connect the firewire cable to both computers and when you turn on your G3, hold the "T" key. This will turn your G3 into an external hard drive and you just have to carbon copy the files straight to your computer's internal hard drive.
If you do not have access to another computer mac computer, then you will need to go to the Apple Store and see if the Genius Bar can install the default operating system that your computer came with.
If for some odd reason you have the contents of an Mac OS install disc copied onto a flash drive or external hard drive, you can boot from that and use it in place of a disc.
Apr 15, 2011 | Apple PowerBook G3 Mac Notebook
I have a iomega eGo HDD and its not showing up on my computer but it shows up under my devices how do I fix that
It depends. If this is the _very_ first time that you have connected the IOMEGA device to your computer, you'll need to "initialize" the HDD for usage by Windows (or Mac OS).
Or, if you've previously done that, and you've written files onto it, and now cannot read those files, you have an entirely-different problem, namely a "hardware" problem.
An external storage device has several major components:
* the USB cable (which in your case, seems OK, since the device is listed)
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure
* optionally, an external power-supply that connects to the enclosure.
Use a multi-meter to measure the voltage/amperage generated by that power-supply,
and compare with the specifications on the power-supply's label.
Disassemble the enclosure, and remove the disk-drive.
Connect it as a "slave" disk-drive in a desktop computer, to see if bypassing that USB-to-disk-drive adapter bypasses the problem.
If the device is still under warranty, IOMEGA will replace it, at minimal cost to you.
If the warranty has terminated, buy a new, compatible, disk-drive, and install it inside the enclosure, to "revive" your external storage device.
Nov 04, 2010 | Iomega Computers & Internet
The icon for my lacie exyernal hard does not show
Here's two suggestions. (If your using Mac OS X 10.x)
Make sure external hard drives are to be shown by clicking "Finder" in the menu bar then "Preferences" and under the "Sidebar" section selecting "External Disks".
Also check that the hard drive is mounting by opening "Disk Utility" by first opening the "Applications" folder then the "Utilities" folder and double clicking "Disk Utility" and in the left sidebar checking to see if your external hard drive is listed as one of the mounted drives. Hope this helps, don't forget to comment/vote if this helped. Thank you.
May 30, 2010 | Apple Computers & Internet
Hello, I plugged in my iomega 1tb desktop hard drive storage device and the drive does not appear in my drive or computer. I do have the new hardware 'sound' that comes up but I dont have the drive show up...
Iomega 1TB Desktop Hard Drive is a dedicated usb 2.0 plug and play external storage device that has an ability to transfer at 480Mbits/second. having these large capacity storage drive needs a fast connection and additional power source to make sure to run the external unit system properly.
just make sure both power and data cables are properly plugged and connected respectively. if you are using it with a desktop, please always plug your usb connection from the Iomega 1TB external drive to the rear USB port in line where you built-in LAN is.do not plug it in the frontload ports. some motherboard manufacturers uses usb 1 and/or 1.1 only for frontload desktop casing provision.
thank you.
Dec 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
External hard drive will not mount on my mac
Bet the drive is toast. Get the correct software and do diagnostics on drive to confirm
Sep 21, 2017 | Iomega 33089 250 GB Hard Drive
Freecom external hard drive classic 2.5
Have a look here>
http://www.freecom.com/ecDrivers.asp
I can't see any Mac drivers for the drive...
I found this page>
http://freecom-usb-osx.sourceforge.net/
You might be able to get some help here...
Jan 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
Failure to read USB connected storage drives
What I have seen with some computer models, is that the USB port cannot deliver enough current to run some devices.
If possible, use an external drive with its own power supply and see if it will work. Most likely it will.
Also, try a powered USB hub. I found that most of the time, a powered USB hub solved many problems with having enough power for some external USB devices.
Jerry G.
Jul 26, 2008 | Apple iBook G3 Mac Notebook
Iomega Zip 750 Drive
Today I try to use my Iomega 750 USB drive and found it has died. There is no light on the drive and I cannot extract the disc out which is within it. How do I get the disc out and is it worth attempting a Fix. Deperately need some help.
Jul 03, 2008 | Iomega (32453) External ZIP Drive
Tony M
get windows. If it doesnt recognise a device, it will go online and get what it needs for that device. As for macs however, your screwed.
Dec 28, 2007 | Computers & Internet
Iomega 33089 250 GB Hard Drive Logo
733 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
