Question about Arctic Sun Pool & Spa
My patio heater won't start. Have new propane tank. Haven't used it in over a year. Tried lighting also with a match.
  • bbaronmd Sep 08, 2010
    My model is Arctic HP110.
    Nothing you sent me was helpful or relevant.
    Barry
  • 22,326 Answers
Try looking at the jets ,the gas jet fires into a tube with the end open so its either bigger or has slot either side ,now what i suspect has happened is a insect has made its nest in the jet hole or this mixer orrifice ,and its normally a wasp that paralises a spider lays its egg on the live paralised spider and then seals it in with mud .This is a common occurance by the way .
Posted on Sep 08, 2010
  • 3,083 Answers
Some interesting answers are on the following web page from FixYa. Since I am unsure of your exact model and type, I will give you the page to scroll and then open up the answers. Here's the page:
http://www.fixya.com/tags/arctic_spa_heater
If I knew for sure what type you had, I would be more specific, but hope this helps.
Lava heater won't light
Try using a match, sometimes spark is not hot enough. be carefulle.
Mar 03, 2014 | Lava Heat Italia Patio Heaters
RTa iNTERNATIONAL propane patio heater
may be the pressure is not sufficient enough,,
check for the pipes...
Apr 13, 2008 | Heating & Cooling
All Pro patio heater modle SPC54PHW, PHB, PHT, PHS. Pilot will not light and burner will not light.I installed a new regulatoe, propane tank is full. Took the gas pipes apart from bottom to top and no...
If your propane tank has an OPD valve.. in other words if when the tank is disconnected and you open the tank valve and no gas escapes..it's an OPD valve..these are pretty much standard especially on the exchangeable tanks.
The problem sometimes is at the connection hose..it too of course must be an OPD connector to depress the internal ring on the tank valve before any gas will come out.
Chances are the knurled knob is either cross threading or is cracked..and won't snug up enough to depress that internal ring on the tank valve. Or you have miss matched components.. unlikely if you bought genuine replacement parts.
The All Pro Heater you have requires a specific part (fitting) to be added when using a universal regulator (Part number 6122) which is a 3/8 connector male.
This of course is assuming you hear no gas hissing.. cannot light it manually..
Sounds simple..but I have seen this problem on outdoor BB'Q's many times.. cracked knob on the connector hose and a few times simply backing it off and putting it back on.. tight enough to depress that ring..
Best of luck!
Apr 12, 2011 | Stainless Patio Heaters - Steel Deluxe...
This is a new unit - used 4 times. The gas will no longer flow and light the unit. Sometimes I can get the pilot to light but when I turn the valve to light the heater the pilot goes out and nothing. The...
Sounds like the thermocouple is not working or you are not keeping the start or pilot button depressed long enough before turning gas valve to on position. Check to see if thermocouple end hasn't come loose, the pilot should be hitting it. This produces the small electrical current necessary to open gas valve. Hope this helps.
Oct 02, 2010 | Stainless Garden Sun Steel Propane Patio...
Fire sense patio heater won't light...
you prob need a new theromocuple on your pilot or just cleen it with sandpaper this may help
Apr 14, 2010 | Fire Sense 01775 Patio Heater
It does not light either by pilot light switch or with a match
If you are sure that your propane tank is not empty you may have a safety feature malfunction. Unscrew the propane tank. wait two minutes and then reinstall the tank. That will reset the safety feature.
Oct 08, 2009 | Blue Rhino Uniflame Patio Heater Stainless...
Coleman 5040 Patio Heater w/ Light - Light works, Heater does not
BE VERY CAREFUL sticking matches in any propane appliance! With the gas OFF see if you can physically see the spark when you push the ignitor, if yes, the problem may be the regulator or bottle pressure the only test i am aware of for the regulator is replacement.
Jul 13, 2009 | Coleman (5040B750) Patio Heater
New bbq won't light
try turning the gas down a little while you use a match?
Aug 07, 2017 | Grilling
Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Regards
Bryan
Oct 19, 2007 | Endless Summer gwt501a Open Flame Patio...
Pool & Spa Logo
505 people viewed this question
Top Arctic Sun Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Arctic Sun Pool and Spa Expert? Answer questions, earn points and help others
