Question about Brother MFC 210C All-In-One InkJet Printer
Just want to SCAN, with image going to computer
MFC continues to beep low/out ink, refusing to initiate a SCAN when button is pushed. I don't use the MFC for copying or printing or fax - just for scanning. Can I disable the ink situation? Thanks.
  • 832 Answers
Machine always refuses ANY function if a color is empty.
You can cheat the machine by sticking some thin black adhesive tape around the cart nose (looking from above onto the cartholder within the printer it is the right hand side of the cart).
This signals the machine a full cart.
Posted on May 15, 2008
Compaq Compaq Presario CQ62 white screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 01, 2012 | Compaq Presario CQ62-112TU
Am I able to scan a picture into my computer. I have windows 7, the model is a mfc-5440cnz and do you need ink to do this? thank you for help
The best way to scan images to save on yourcomputer is to use the scanner software on the computer. Not the scan functionon the scanner.
You don't say what type of scanner software you have but usually scannersoftware works this way:
1) Place photo on scanner
2) Open scanner software
3) Using the software, Initiate scan
4) Name the Scanned item and save it to your desired location/folder
Note: some applications will automatically save to --My Documents--My Pictures
5) Repeat process for each pic to be scanned
Also, if you are just scanning, it should not matter what the ink situation is.
May 01, 2011 | Brother MFC 240C All-In-One InkJet Printer
How to reset error e4
The reset method work for canon printers that using PG-40 and CL-41 cartridge. After doing this reset method canon printer will not display low ink notification anymore and will not show error code “E4′ or “E5′.
Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset ink level notification:
  1. Push “resume” for 5 seconds for canon IPXXXX. For canon MPXXX you must enter to service mode.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Enter to service mode for canon MPXXX
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
Apr 15, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Resetter
http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
The reset method work for canon printers that using PG-40 and CL-41 cartridge. After doing thisreset method canon printer will not display low ink notification anymore and will not show error code “E4′ or “E5′. This method takes from indoreset yahoo group and prepared by Choy.
  8. Open cover
http://downloadprinterresetter.blogspot.com/
OK, go to website above, and download a "Resetting" tool, this makes resetting easier to do.
Apr 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Low ink warning not right. ink is full. What to correct warning?
According to the information on the website, you should be able to press the Stop/Reset switch for about 5 seconds to disable ink level monitoring on the empty cartridge.
Feb 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
Won't scan. alarm light is on say's out of ink but has been refilled all buttons when pushed dubble beep.
Your refilled cartridge didn't get the ink level chip reset. Your printer will refuse to print, scan, copy, etc.. until you replace the cartridge that's "empty." I would return the cartridge to the refiller you purchased it from and buy a refill from Cartridge World. These simple problems do not happen with Cartridge World refills.
Jan 19, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I desperately need to perform a scan, but cannot
There is a sensor in the printer that checks ink levels. The sensor uses a beam of light to do so; if the light bounces back, the machine assumes there is ink in the cart and continues to operate. If the light is not bounced back, the machine assumes that the cart is empty and starts beeping and won't allow any other functions until cartridge is replaced.
Take a piece of black electrician's tape and placed it on the cartridge’s spine. The sensor will assume the cartridge has plenty of ink and will function.
Nov 15, 2009 | Brother MFC-5840CN All-In-One InkJet...
Mfc-9420cn scan button does not initiate a scan
You should switch to scanning mode on the printer's interface!
Jul 15, 2009 | Brother MFC-9420CN Laser Printer
Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
Dec 10, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
193 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
