Question about GE GSL22JFPBS Side by Side Refrigerator
Hi, This is the closest Model # I could find to mine. Mine is Model # GSL22JFRE.BS. The problem I am having is the freezer is only as cold as a fridge and the fridge is only has cold as a cooler. We got it used and it worked for about a month and then started doing this. Can you help? Thanks, Debi
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 08, 2010
Maytag model MBR2258XES4 refrigerator and freezer not cooling well d
I had a similiar problem with mine..it ended up being the defroster board..it seems to kak out every 3 yrs..mine was under the temperature control panel..it was in a white box inder the cover..good luck.
Mar 25, 2014 | Maytag MBR2258XES Stainless Steel
GSL22JFRE BS Freezer OK but not Fridge ??
Clean the condenser grille, rear and under unit
Apr 24, 2012 | GE GSL22JFR Side by Side Refrigerator
Hi, where can I get a picture of the front panel settings for my dw1292 dishwasher, as mine is not readable anymore
I am having difficulty finding a frigidaire dishwasher with that model number.
Please confirm the source country of the model.
Please check this manual and confirm if the picture is closest to your model.
Aug 08, 2011 | Frigidaire Dishwashers
I have a GE Model GSL25JFPH BS refrigerator and the water through the door just stopped working. Still getting ice, but no water
I have the same MdL. mine freezes in the door, it happens all the time, I take the freezer door off and take it outside and run a weed eater line up through the tubing in the door when its clear you can blow through the line, I will be buying different brand next time, and last night the freezer will only get to 28deg and that's all it will do. its eight years old and we have had problems from the day it went out of warrenty.
Jun 12, 2010 | GE Refrigerators
GE Frig GSL22JFTA BS
If you get water at the bottom of the door then something is blocking it between there and the dispenser. Usually ice. Leave the door open and cover the freezer opening with a blanket to keep freezer cold.It should thaw in 156 or 20 minutes.
Oct 08, 2009 | Refrigerators
Where is the thermostat on a GE profile refrigerator Side-by-Side
There is no thermostat ( cold control ) on your model refrigerator . It works off thermistors ( 3 in the refrig section and 2 in the freezer section ) . These thermistors , operate by the coldness which in turn , less resistance to the main control board the colder or warmer it will provide .
Sep 12, 2009 | GE Refrigerators
GSL22JFRE BS not cooling. I need help troubleshoot my GE GSL22JFRE BS cooling issue. I found a temporary fix from this website by open up the "frosting-panel" in the freezer and blow-dry out the ice. It...
Hi, Ifwhat you are getting is frost, remove the rear panel again and locate the defrost heater. There will be two wires going to it and it is fastened to the bottom of the evaporator coil.Remove the two phillips screws holding the heater and pull it out to remove the wires. Check the element for continuity. If there is no continuity on the element, replace it. If the element shows ok, locate the bi-metal switch that is fastened at the top of the evaporator coil. Test it and make sure it has continuity. NOTE: the bi-metal must be tested while it is cold.
The most common problem with this model is the defrost heater.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 20, 2009 | GE GSL22JFR Side by Side Refrigerator
Which setting on an Energy Miser saves energy?
OFF is the Energy Saver mode.
To reduce moisture, there is a heater around the door seal that stays turned on, using energy. If you switch to ON, you use more energy.
It is confusing though.
Jan 17, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
POWER LIGHT FLASHES ON / OFF
You need to install or change the battery for the power out freezer alarm. Mine was just doing the same thing. I looked on the web for the answer and couldn't find it. Opened the door to look for the model number and there was the diagram for the light flashing codes. Mine's battery compartment is in the grill on the bottom (right below the door) on the left side. Takes a 9v battery. I had a power outage recently and it must have killed the battery after beeping for several hours.
Mar 21, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
GE GSL22JFPBS Side by Side Refrigerator Logo
79 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
