Question about GPS
Streepilot c330 won't stay on
My streetpilot worked good yesterday and tody it turns on and shuts right of f,
    Genius:
  • 3,422 Answers
HI,
Did you make sure it is charged properly?
Posted on May 14, 2008
  • Priya darshan May 14, 2008
    Also did you try reseting it?the first thing is connect it with the charger and then do a reset..
    You can try both a normal reset or a master reset and see if either one works for you.
    The normal reset button is behind the front bezel. You access it by
    using your thumbnail under the top part of the bezel and carefully pull
    the bezel off. Once off you press the reset button on the right side of
    the front face labeled reset.
    Option #2 - Master reset, will lose all data.
    With the unit off, use a pencil eraser to depress the bottom right
    corner of the screen while turning the unit on. Once on, let go of the
    on button and keep the lower right screen depressed and answer yes to
    do you want to reset unit and lose all data.
Brand new unit.Garmin c330, Will not stay on.
Since I didn't hear from anyone, I contacted the co. I purchased from. I was advised to send it back.
May 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot C330
Verify that you are getting 12 volts from where you're connecteing this device.
May 14, 2008 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
You will need to reset the device.
1. On the silver faceplat, under the word "Garmin", there is a tab. Remove the silver-ish fram carefully by pulling on the tab with your nail then by the sides.
2. once removed, press the reset button.
3. Once reset, the unit should work properly.
May 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin streetpilot c330 problems
my c330 shuts off after 3 seconds and then wont start back up . on battery or adapter
Apr 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Free updates
first, you take cd ver 5.7 and coy to on your pc and then run your ver5.7. then a dialgbox see in your desktop then you click on ok/yes
then no take action lease contact me.
Nov 22, 2007 | Garmin StreetPilot C330 GPS Receiver
Mi streetpilot shut down when it's not pluged
Dead Battery. Garmin will replace battery for a charge if the unit is out of warranty.
Aug 10, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
19 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
