Question about Weber Genesis Silver C Grill
MY FLAME IS TO HIGH EVEN WHEN I SET IT ON LOW
  • 43,501 Answers
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 08, 2010
I have a heatilator gas fireplace model gcdc60 and the flame is not high anymore. This fireplace has two settings low and high. The high setting is like having low on and the low setting is almost not...
Take a thin stiff wire and run it thru each flame port of the burner a few times each then if you can take a vacuum after setting it right on the ports-tap on the burner with a object while vacuuming it-if that does not work -is there a place that looks like a nut over each flame port? if so spray with a lubricant like WD40 to loose the nut and remove and clean flame ports that way and vacuum it then same way then
Sep 30, 2017 | Home
Low flame
Out of gas or spiders in the jet
Apr 13, 2010 | Char-Broil 7000 Quick Set Gas Grill
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
Gas stove causing soot on everything
all of the burners are set to rich...open the vents on the burners more.  If this doesn't help you need smaller nozzles.
Mar 26, 2009 | Whirlpool Gold GW399LXU Gas Range
Low flame even on high
Check the propane regulator if equipped
Check the gas orifices - they may be carboned up and require cleaning
Check the venturi tubes (the tubes that go over the gas jets) - they may have spider webs or other insect cocoons in them
Make sure the gas valves work correctly (high/low)
You mentioned that you replaced the burners - are they correct for the unit and installed ok?
Make sure the gas valve on the propane tank is opened all the way
Mar 22, 2009 | Grilling
Had a new gas hob installed but two of the gas burners only have a very low flame even when turned to high. One of the others has yellow flame tips even on low and is leaving marks on the bottom of the...
propane or natural gas? if it was converted inproperly it will leave soot on your pans. also you will see flames when you bake with it or broil.
Nov 01, 2008 | Kitchen Ranges
Gas Grill - flame always stays on high even though I've turned in on low
hey buddy that use to happen to me so what i started to do was once the fire was high i use to turn the gas off i hope this helped.
 infamouspk
Oct 07, 2008 | Sport & Outdoor - Others
Cant find the set screw to adjust the flame
some arent adjustable any more, did you look down the center of the knob shaft???? most common place for it
Mar 16, 2008 | GE 30 in. JGP990SELSS Gas Cooktop
Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Jun 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Weber Genesis Silver C Grill Logo
99 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
