Question about Compaq Presario S4200NX (DF215AR#ABA) PC Desktop
When I start-up my Compaq Presario S4200NX - I get the Compaq logo and a continuous beep and it doesn't go any further. I've read some posts and its pointing to the memory card being bad. Is this the case?
  • 83 Answers
It is possible that the memory sticks(RAM) are busted or cannot be read anymore. If you have multiple memory sticks, try isolating the damaged memory stick by using 1 memory stick at a time and try starting your computer up. Once you have found the busted one, try replacing it with a new one.
Hope this helps!
Posted on Sep 08, 2010
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
I have a compaq presario desktop S217ONX with two I-Inc monitors. I recently had to reinstall Windows Basic and only one works. I have read enough to be dangerous! Information is to go into BIOS adnd make...
Presarios normally let you access BIOS setup by pressing F10 as soon as the Compaq logo pops up on the screen when starting it. I've read that F1 is the key on some pre-2006 Presarios. Pressing the F10 key multiple times immediately after starting can be helpful.
Aug 21, 2011 | Compaq Presario SR1050NX (DW257A) PC...
Compaq presario m2000 notebook continuously beeps while starting up. The computer is very slow once fully logged in. Do you have any suggestions to fix these problems?
The beeping usually points to a RAM stick failure. If your laptop has two sticks of RAM then one of them has failed, which further explains the slow performance of the laptop once it's fully loaded.
To troubleshoot this issue, you'll need to remove one RAM stick at a time, and see if the laptop boots at all. When you have only one stick of RAM and the laptop does not load after the beep signal, then that installed RAM stick is bad. You may want to try and clean up the contacts with a cotton cloth and some alcohol just to make sure it's not an oxidized contact issue.
If this was informative and helpful please vote with a Thumb Up. Thank you.
Feb 01, 2011 | Compaq Presario M2000 Notebook
Compaq Presario S5100NX Desktop PC 1 LONG BEEP AT START UP I GET THE COMPAQ LOGO BUT NOTHING ELSE. THANKS FOR ANY HELP.
One long beep usually means a memory or RAM error..
Try removing the ram sticks and then simply replacing them back into the slots..
The contacts in the RAM slots are self cleaning to taking the sticks out and putting them straight back is usually enough to correct this issue..
Just make sure you touch part of the metal chassis of the tower BEFORE you touch anything else.
This will discharge any static charge you may have on your body..
Dec 19, 2010 | Compaq Presario S5100NX (E120866) PC...
There is recovery partition on my compaq presario CQ50 - 209wm and I'd like some help oh how I can use that to restore/reinstall my vista?
Normally during the early start sequence (when the laptop displays the Compaq logo), you will need to press F9, F10 or F11 repeatedly (model varies)
Some also require you to hold the key down before you press the power button, then release it after the laptop has finished displaying the Compaq logo.
Hope that helps.
If you are still lost, post back.
Peter
Mar 26, 2010 | HP Compaq Presario CQ50-103NR Notebook PC
How do I acces the Bios on a Compaq Presario 5000 built somehere around 2002.
during the bootup post routines you should see a message that tells you what to do to go into the bios.
Sometimes the post routine is run without being shown on the screen. If so, try pushing the F2 button, or DEL key during the bootup sequence.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
'03 compaq presario x1000
On a desktop pc u hear continuos beeping it's something to do with da ram so try replacing the ram or reseat the ram for help go to compaq.com
Nov 11, 2008 | Compaq Presario X1000 Notebook
COMPAQ PRESARIO SR1010V!!!
If the hard drive is is not damage maybe you can save all important files on it.
Please do the step by step troubleshooting of your laptop.
REmove the following:
1. Memory
2. hard drive
3. processor:
4. Battery
try this;
1. Fix some other connection inside the laptop
2. Insert AC plug then start the system.
3. shutdown the system
4. Insert the processor
5. swittch on the laptop.
If beeping; continue
step 3;
6 insert the memory.
7. start the system
8. If display, connect the harddrive.
in step 5: if not beeping:
Either board or processor is dead.
IN step 8.
9. start the system.
10. if the hard drive is detected, and cannot continue booting
i recommend you to reinstall the windows.
Please notify me if problems arises. i will give you further instruction, melnavz.
Feb 04, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Compaq Presaio S4200NX displays Compaq Splash Screen then a single continuous beep with but nothing else.
Most Compaq desktop that exhibits 1 long never ending beep indicates Memory error; Bad RAM. Corrective measure therefore would be replace and test.
You can try removing the memory and cleaning the gold pins with a pencil eraser and try again. If this doesn't work, guess you're back to replacing.
Good luck and kind regards.
Nov 04, 2007 | Compaq Presario S4200NX (DF215AR#ABA) PC...
Compaq Presario S4200NX (DF215AR#ABA) PC Desktop Logo
108 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
