Question about Whirlpool RF364 Electric Kitchen Range
The burners on top all work stove will not heat up
  • Whirlpool Master
  • 43,501 Answers
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Sep 08, 2010
Tip
Electric stove burner won't heat sometimes heats
If you electric top burner stops heating or intermittantly heats the most common problem is a loose connection where the actual burner connects within the socket (to make an electrical connection). It will over time become loose and/or corroded. To do this you simply lift the top portion of the stove up (remove the grates prior to doing this.Normally you can squeeze the pins inward slight so the burner makes a good contact and use a piece of sand paper to clean the contacts.
on Dec 22, 2009 | Kitchen Ranges
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Stove top want heat up
the bulb i am sure is ok . but you have had a power failure to the burner . it could be the burner itself . if all the burners do not work the power to the range may be the problem .. ck the main fuse and make sure the 220 power is ok mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
I have kitchen aid in the counter range, the bottom heat element is bad. The element has burnt and has a 3" piece that has separated. At the same time the oven stopped working the burners stopped working...
The oven element will not affect the top burners, Unless it tripped the breaker at the panel when the element burned it two. Is there power to the stove? The top burners have their own power and control separate.
Aug 01, 2009 | Kitchen Ranges
My oven made a buzzing sound,and and smoke came out form the oven. Now it wont heat up, but the top stove still works...Any ideas? Thanks
fryed switch or fryed burner
if smoke came from inside stove likely the burner is fryed
try setting oven to broil and see if it heats up
if it does replace lower burner
Jul 31, 2009 | Ovens
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Whirlpool RF364 Electric Kitchen Range Logo
105 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
