Question about Bunn BX HOME BREWER 10-Cup Coffee Maker
My bunn stopped working completely. It will not heat water and warmer wont come on. All switches are in correct position
    Sergeant:
    Novelist:
  • 193 Answers
Plug something else into the same outlet and see if you are getting electricity in that outlet. If it is on a ground fault circuit, push the little red button in in the middle of the outlet. or check the breaker box to see if the breaker has kicked. It is unusual for everything to quit working at the same time if it is getting power.
Posted on Sep 08, 2010
  • amaizenblue Jan 16, 2011
    I agree it's unusual 4 everything 2 quit working at the same time, but mine did. Checked main switch with tester I've got power going into and going out of the switch. Still nothing. Only a little over a year old. Frustrated, just doesn't make sense
Well i've had the same exact problem with this model back in 2011 . Bunn exchanged it for same model just had to pay shipping. It was still under warranty. But here is the kicker my replacement BX-B is 2 years old and is not working. Should this be a hint to Bunn that there should probably be a recall. To many people i know that have this model have same issue. I followed all the guidelines in the care of my Bunn. I'm done gonna buy a different brand.
Posted on Oct 04, 2013
  • M. Nash Jan 25, 2014
    I have the exact same problem. Just out of warranty and it completely stopped working.
My warmer plate light does not work and the water in holding tank feels warm on top not on bottom,coffee is not hot enough to dissolve powderewd creamer.Why?
No warmer plate llight:
Usually means bad switch. Bunn Part no. is 20316.0001. Replacement available at link below.
Bunn Home On Off Warmer Control Switch Lighted
Note differences in switch wiring in photo below between old and new style switches.
Coffee not hot:
Make sure "Vacation Switch" is in OFF position.
Aug 07, 2014 | Retail Supplies
My 2 year old Bunn coffee maker was working last night but I went to make coffee this morning and the water was not hot, the switch on the side was off and the warmer wouldn't come on. I tried another...
Most probably the relay that drives both the heating element and the warmer.
A black thing like little box (relay)that containes 8-6 wires (2 from main board and rest just go other components.)
Thanks
Please rate my work
Sep 17, 2011 | Bunn NHB Coffee Maker
My warmer switch on my bunn coffeemaker went out and wont come back on, what is the problem?
For us, it is a faulty switch. This may be a warranty issue -- depending on how old your coffeemaker is. We had to send back the heating UNIT ONLY at our cost. The good news is that we got a COMPLETE replacement. Now we have an extra basket, glass server, etc
Oct 29, 2010 | Bunn 10 Cup Home Coffee Brewer
My Bunn just stopped working. It does not heat the water and the warmer for the pot does not work either.
Did you check to make sure the switch on the side of the machine is in the correct position-the "I" pushed down and the "O" up in the air and you see orange around the switch? If this is correct, then please give customer service a call at 800-352-2866 with the model and code date.
Aug 07, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
I just get bunn VPS it is and work very good
The switches are for the "warmers" only. The brewer has a reservoir the keeps water hot and ready for brewing. When it is not re-heating water (after brewing) it has a "keep warm" heater that is low voltage and keeps it ready to go.
May 16, 2010 | Bunn VPS Coffee Maker
BT-10-B Bunn Thermofresh that will not heat or fill pot
Lots of times minerals clooect on the heating element and inside the heating chamber. The easiest thing to try is to put white vinegar into the filler, displacing some of the water into the pot. Leave this to soak for about an hour, then flush with several pots of water until the vinegar smell cannot be detected in the water. Make sure that the switch on the side is "ON". You may have an indicator light. The switch on the upper front is for the warmer. The reason you only got a partial pot of water is that the reservoir wasn't completely full. Once you have filled it completely, you should fet a full pot out for every full pot in. If all of the above gives you no relief, you may need to test the heating element for voltage and continuity. If it tests 'open', you will need to replace it.
Good luck, --W/D--
Jul 17, 2009 | Bunn B10 Coffee Maker
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Slow recovery on bunn o matic for next cycle
You could have scale building up on the heating element and thermostat probe. try running a 1/3 white vinigar - 2/3 water mix into the brewer, let it heat up completely, then run several pots of clear water through the unit. keep pouring water through it until the vinigar smell is out of the water,
Jan 05, 2009 | Bunn-O-Matic Coffee Brewer GRW8
I have an older Bunn-o-matic with 2 extra warmers on each side. The water is supplied automatically to the machine but is not heating up, despite my turning the heat knob all the way up. The warmers are...
Here are some possible causes ,the hi temp cut out ,thermostat, or heating element are bad .a continuity tester can determine whitch one .Also you could have a burnt off wire . The reason the water is still luke warm is a electic warming jacket that bunn put around the water tank to limit the therostat cycles during off peak usage very fixable hope this helps
Dec 29, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
May 20, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn BX HOME BREWER 10-Cup Coffee Maker Logo
1,608 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
