Question about Goodman Heating & Cooling
My new goodman air conditioner is not putting out cold air the air is bearly cool. Is it the thermastat or the air conditioner. Please help.
    Master:
    Sergeant:
  • 449 Answers
Your condensor sounds like its not working check the breaker box
Posted on Sep 08, 2010
My indoor fan motor comes on even when the thermastat is off
Is your thermostat perhaps programmed with a circulation option. Many modern thermostats have this option. check your fan options. They may be On,Auto,Circ. If it has a Circ or Circulation option, your indoor fan will still periodically turn on according to ASHRAE standards, even if your stat is turned off. if you poke the fan button you should be able to choose auto and this will solve your problem. Hope this helps.
Dec 17, 2012 | Goodman Manufacturing Goodman GSC130181...
I have a ( Goodman CKL-49 1 ) fan was not running, I used a small wooden stick to get it to run. fan is now running but cold air is not being produced what can I do can you please help?!
The split run capacitor in the condensing unit is bad. It needs to be replaced. The reason the system is not cooling is because the compressor it not running. The capacitor is needed for the fan and the compressor to run properly. That is why you had to give the fan a kickstart with a stickstart.
Hope this helps.
Sep 08, 2011 | Goodman CKL49AR49 Air Conditioner
I have an intertherm air cond.it blows cool but not cold air,i have all conections no leaks and everthing runs when i shut the air off at the thermastat the blower keeps running any thoughts please help....
Several problems with these units, (I just finished rebuilding mine). sounds like the fan
relay has failed. This may be due to water dripping on it. Also the sequencers that
were supplied often popped apart( the new ones are clipped together with metal bands)
I would replace both as I have already done.
The outdoor condenser sounds like it is stuck, which is a reversing valve problem.
If the lineset is cool but not really cold, then this is the problem.
luckily the parts are inexpensive for the air handler but the outdoor unit problem
is expensive to repair and I just replaced it as a unit, The good news is that it dropped
the electric bill 84 dollars the first month in february heat mode.
If you can install a new system, I would recommend a Goodman 13 seer minimum. They
are efficient, quiet and less expensive, if your unit is 13 seer on the indoor
air handler it can be
fitted up with a new outdoor condenser. Hope this is useful.
Jul 18, 2011 | Heating & Cooling
Goodman air conditioner is sometimes blowing out warm air. We've had this unit for 2 and 1/2 years. When we first moved in we had a problem with it not blowing out warm air in the winter. We had someone...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 30, 2010 | Heating & Cooling
1 1/2 ton goodman outside unit made a hissing
Hello Scott,Your new ac is OVERCHARGED with freon.Shut it off,let it cool down and recover/remove freon.The compressor has an internal pressure valve that makes the (hiss).It will stop when the charge is adjusted.Call them back to do it.
Jul 31, 2010 | Goodman CKL36AR36 Air Conditioner
I think i have a bad fan motor bearing. Unit is very loud and barely cooling.
The bearing may be going bad, but that should not effect the cooling much if the fan is running...there must be other problems...
Here is a tip for other things you can check....
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 30, 2010 | Goodman CKL24AR24 Air Conditioner
I just had a new Goodman 13 seer installed on 6/5/10 and the unit wont turn off and doesnt seem to cool down the house had new duct installed also they changed out the fan but it runs all day without...
CALL AN EXPERT......THE WIRES AT THE CONDENSER ARE NOT CONNECTED PROPERLY.THE UNIT SHOULD HAVE BEEN VACUUMED/PUMP DOWN BEFORE STARTING UP .POSSIBLE LOW ON REFRIGERANT ALSO.
Jul 13, 2010 | Goodman CLQ36AR49 Air Conditioner
Freezing Goodman pipes
make sure the filter is clean. also the evap coil should be clean. if none of these then your system is probably low on charge. hope this helps
Jun 05, 2010 | Goodman CKL42AR42 Air Conditioner
We put in a new thermastat and now the ac wont work. Is there a fuse?
R--redwire-power y-yellow wire -cool g-green---fan w-white -heat. If you turned it off &back on too fast, then you probably did blow the fuse on the outside unit or triped a breaker, check your fuse box ,or on the outside wall, theres a gray box called the disconnect box that sometime, house 2- fuses or a plain pull-out with no fuses.
Sep 04, 2008 | Goodman Heating & Cooling
Furnace blower needs repair
Hi,may be your Fan motor shorted ,pls check the that lead wire of FM.
Regards,
Edgz
Feb 08, 2008 | Goodman CPLE24-1 Air Conditioner
Heating & Cooling Logo
82 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
