Question about GE Refrigerators
How to install GE side by side lower door hinge cam riser
4 Suggested Answers
  • 531 Answers
SOURCE: GE TFS28PB Lower Hinge on Fridge door defective.
you have to get cam closure part # wr2x9246 and door stopper wr2x9247
Posted on Apr 06, 2009
aasc
  • 1606 Answers
SOURCE: . I need the hinge door stop on the lower right side of refridge
The door stop part # WR02X10782 If this is for the refrig door , check the screw at the bottom of the door , to make sure it is not adjusted too high , bypassing the door stop . The same door stop is used on both doors .
Posted on May 09, 2010
TheMobilian
  • 8220 Answers
SOURCE: ge profile .. refrig water leaking from freezer
Must be the line going to water dispenser. The manual below has pictures. Use it as a guide to repair the leak.
PSS service manual
Posted on Aug 17, 2010
Refrigerator door
If there is nothing blocking the door from closing than more than likely the cam riser on the hinge has broken and causing the door to not line up properly. Look at the hinge on the other door and compare to see if there is a plastic piece that is missing or if there is a difference is looks.
Sep 05, 2012 | GE Monogram Side by Side Refrigerator
The right door of my Kenmore side by side
You may have a broken cam riser which is located at bottom hinge. Compare the 2 hinges with the doors open. The right side is probably missing 1 piece.
Feb 16, 2010 | Refrigerators
How do we adjust the door height on our GE Profile Side by Side frig, Model TPX24BPZC...it has slipped down and the trim kit keeps rubbing on the lower edge where the door hinges....????
Hello, Take the cover off the top hinge and then remove the top hinge and the door, the problem may be a worn hinge cam, if it is replace it. If the hinge is loose tighten the bolts. Once the door is off you will see how the lower hinge can be adjusted. Hope this helps! Mike
Dec 02, 2009 | GE Refrigerators
Door wont closeDoor needs to be lifted to shut correctly
the cam riser may be broken on the lower hinge of the door and that's why you have to lift it up. this is also called a door closer. see #18 in the breakdown attached.250
Oct 27, 2009 | Hotpoint HSS25GFP Side by Side...
Same problem but part is not on schematics for my model.
that is what helps your door close..if the cams are broken the door will drop down and may drag..if that is your situation then yes, get that kit.
Jun 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Doors don't swing shut automatically
The GE side by side refrigerator has 2 cams on the bottom hinge that helps shut the door. If the cam wears out then the door will not close properly. One of the cams is riveted to the hinge assembly and an extra cam is shipped with it. The cam assemblies can easily be replaced by using the information on the Partselect.com website that refers to the GE TFX22R refrigerator.
Apr 25, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leveling old refrigerator
The refrig does not have to be level, as a matter of fact, they tend to work (doors on most refrig's) if the front is a bit higher than the back. If you pop off the lower grill, you will see that the front rollers have a bolt that runs up through the lower frame. Turning on the end of that bolt with a 3/8 inch wrench will allow adjustment of an inch or so, up or down, depending on where it is at now. Only the front rollers are adjustable this way. Back rollers would have to be shimmed to adjust. Check the door hinges to see if the hinge and corresponding hinge cam riser (WR2X4901) are worn. (these parts raise the door slightly as it is opened, and help close the door as the door drops back down when closing.)
Dec 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Replace WR2X4901 cam riser with ice maker tubing
hi janice i will be glad to help or maybe you already fix it you have a coonector behind the kick plate disconect the line from connector remove door screws from top and remove the whole door while some else guide the hose throught the hole on bottom hinge and there now you can repl the cam riser then just follow the same directions to repl door back and that is it thank and please if i was helpful take the time to give a rating thanks
Sep 10, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore refrigerator door
There is a part on the lower door hinge & on the bottom of the door called a door cam riser & that needs to be replaced
Jun 24, 2008 | Kenmore 44103 Side by Side Refrigerator
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
