Question about Craftsman 22" Gas Hedge Trimmer
I am looking for a choke lever for a craftsman gas hedge trimmer. Model number 358.769356. Craftsman website doesn't recognize the model number. Any ideas?
5 Suggested Answers
sparksflyin
  • 47 Answers
SOURCE: fuel line replacement
pull the lines off do only one at a time one should stick in the tank 1/4 inch which is your return the second one is your pick up which has a filter in the tank attached to it take a piece of stiff wire or a clothes hanger and bend a tight hook on the end just big enough for the fuel line to fit in it fish the wire in the tank and try to hook the fuel line then pull it out of the tank to take the filter off it might take a few tries but you will get it after that pull the line out from the top not the filter side take the new line and feed it through if you cut a 45 degree angle at the end of the line it makes it easier to feed once you get it in all the way use your piece of wire to hook it through the filler and pull it out then attach your fuel filter then shove it back in the tank like i said it may take you a few times but you will get hope this helps
Posted on Feb 08, 2009
  • 398 Answers
SOURCE: Craftsman gas hedge trimmer
yes the throttle isnt giving enough gas. there should be two screws side by side somewere near the trigger next to the cable that moves when you pull the trigger. play around withthose screw a few hours youll get it.
Posted on Feb 26, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
SOURCE: I'm having problems figuring out how to change or
remove screws on both sides of plastic housings, remove spark plug, pull off plactic cap on the bottom side of the clutch plate. stick a wooden stick in that hole to keep the crank shaft from turning when you put an adjustabloe wrench on the clutch, unscrew clutch to get other half of housing off to get to the pull rope.
Posted on Aug 13, 2010
Craftsman 22 in. electric Bushwacker hedge trimmer handle is broken where can I get part number?
Call your local sears store for their national parts department 1/800 toll free phone number.
Then write down the MODEL number [and a serial number if available]. Then call the parts department, give them the model number and they should be able to give you the part number.
Just to be as fully prepared as possible, have the actual trimmer with you during the calol so that you may be able to answer ID questions the parts tech may ask.
Apr 23, 2014 | Craftsman 22 In. Electric Hedge Trimmer
I need a primer bulb for a CRAFTSMAN GAS HEDGE TRIMMER model 358795660. Sears doesn't sell just the primer bulb. You have to buy the entire carburetor. Can you find me just the bulb?
As far as I can tell your machine has a Zama carburetor on it. The Zama part number is 0057025. Any small engine repair shop that deals with two stroke engines can get you one. You can get it online but the price for the bulb is about $1.50 and the shipping would be around $3.00. I would check with your local dealer first.
Sep 21, 2012 | Craftsman Hedge Trimmer With Rotating...
I have a craftsman weed wacker model 316.79197 It will cut off when i pull the trigger to give gas. what should i check ?
Be sure the exhaust port is not clogged. Be sure the choke lever is in the run position. Also you might try letting it warm up half choked before you "pull the trigger"
Apr 02, 2012 | Craftsman Garden
Manaul for Craftsman electric trimmer 358.783522. I went on the Sears Parts website and could not find the manual. Do you have any other suggestions on where to locate it? The Craftsman webiste was of...
I see the manual listed after part number 25 in this Sears Parts Direct.com website. It is inexpensive and if you can view a complete parts breakdown of the unit here, maybe you won't even need to order a manual. Usually they are a free download. Here is your model:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358783522/0247/1503820/10059474/00001?blt=06&prst=0&shdMod=358783522
Apr 13, 2011 | Craftsman Garden
I am looking for a parts schematic for a sears hedge trimmer modle 636.796670 20.3cc engine also has anyone know or a repair for plastic gas tank
An illustrated parts list is readily available at www.searspartsdirect.com . Just input your model number and select model search.
The gas tank is located in the "crankcase" section.
As for gas tank repair, I have tried many times to repair these tanks. I have not been successful, even with the epoxies that are specifically made for it.
Good luck.
Oct 20, 2010 | Craftsman 22 in Hedge Trimmer
Hedge trimmer broken
Any local repair shop will do this for you - if you're looking for free repair -then please - look at the local sears store to direct you as they have the locations there.
Thanks
Gary @ Fix Ya
Jun 30, 2010 | Craftsman 22" Gas Hedge Trimmer
I've got a craftsman 22 in. hedge trimmer (electric) and I'm looking an attachment to enable me to trim my hedges, which are approx. 8' tall, without climbing up on a ladder to trim the tops of the hedges....
Un less your trimmer is a split sharft model ie you can take of the blade by undoing a handle then the answer is no you will have to buy a diff trimmer
Jun 28, 2010 | Craftsman 22 in Hedge Trimmer
Craftsman model 358.796354 quits running after 5min. (coil poss.)
it could be getting the wrong fuel mixture or the engine is getting hot
Apr 19, 2009 | Craftsman 22" Gas Hedge Trimmer
Craftsman 22" Gas Hedge Trimmer Logo
121 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
