I have a h470 having problems printing. did a self check and it printer up error code 805d0a61 (pen alignment not aligned) how can i resolve this problem. thanks; rich
SOURCE: Alignment problem
Try swabbing the print surface of the color cartridge with a q-tip and a little alcohol. It may be clogged.
Posted on Feb 22, 2007
  • 85 Answers
SOURCE: HP PHOTOSMART PRINTER C4280 PROBLEM: PRINTER WILL
what error u had got please tell me . also u can uninstall ur printer and again install it
Posted on Jun 03, 2008
SOURCE: Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Posted on Aug 18, 2008
teknowolf
  • 207 Answers
SOURCE: my printer has new ink
Under the start button go to the Printers folder and verify whether or not your printer is listed as the default printer, when you ran out of in it may have defaulted to another printer or vitual printer(ie.... a pdf compiler) If that is your problem, simply right click your printer and select "Set as default"
If this is not the case I need some more info. What is the manufacturer of your printer and what model is it? How does it connect to your PC (USB, ethernet,Wifi, or Parrallel port)
Hope this helps
Dave
Posted on Nov 07, 2008
futureloginn
  • 734 Answers
SOURCE: Trying to align after inserting
please give detail about model number.
Posted on Dec 04, 2008
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
HP C6180 all in one printer My printer will not print light magenta and magenta, all the other colours are fine. Tried everything Any suggestions Thanks Paul
This problem seems to be with the printheads of the printer If magenta ink cartridge has enough ink inside it and if print heads are damaged then you need to replace this printer.....
But still if u want you can follow the below mentioned steps :
If it is not printing in light magenta and magenta than you can try the below mentioned steps :
Step 1 - First clean print heads from the menu of the printer. You can look for clean printhead option under printers menu - Tools - Clean Print Heads.
Now print and see if it is printing or not. If issue is not resolved then move on
Step 2 - Check if your magenta ink cartridge & Light magenta ink cartridge has ink in it or not...if it is empty or if has very low ink then.....
replace it with a new ink cartridge......and now it is going to aling the printer....While it aligns it is going to make noise and will show a message printer aligning or alignment in process.
While it aligns dont touch the keys of the printer or dont interrupt in between the process otherwise hardware of printer might get damaged and you have to replace the whole printer
...and just wait...till the printer display shows the regular menu...
Note : - * During Alignment printer is going to consume more ink, so make sure you have enough ink in all the cartridges or otherwise it does not have enough ink in it
alignment process will not be completed properly.
Steps 3 - If it prints an alignement page then it is ok, check if all the colours on the alignment page and if all the colours are fine then ur issue is resolved...
for verifying you can print another document.If it does not print any alignment page then you can try printing an alignment page from the printers manually from the printers menu.
Now if it has resolved the issue then it is fine or else last you can try re-setting the printer.
Re-Setting the printer :
- Press and hold the "*" key.
- Press the "#" key and release both keys.
- Display should say "Enter Special Key Combo" then release the keys and press "1", "2" and "3" buttons in sequence.
- then you will get few options, now look for an option that says System Information or System Menu
- Press "OK" on System menu and look for an option Semi full re-set
- Press "OK" Button.Now printer will shutdown automatically and will turn on automatically after few seconds..as it is going to align the printer..
- Now it will make noise for few minutes wait till then and when you see regular screen on display then print a document and see if issue is resolved or not.
If issue is not resolved then you need to replace the printer. If it is in warranty then contact Hp customer care and they will replace it for free.
Feb 25, 2011 | HP Photosmart C6180 All-In-One InkJet...
My printer is not working it has flashing green and orange lights
To resolve this error you will need to remove the ink cartridges and the print head.
Gently, wipe clean the print head and the cartridges with a moistened cotton swab.
Replace the components and make sure that the parts are seated securely and well placed.
Now, to check for alignment, run the cleaning and alignment utility.
This should help in resolving the error.
Sep 07, 2010 | Canon i860 InkJet Photo Printer
How do I align the print head
please go to the properties of printer and check there will be option in tabs to align and clean the head.
hopefully your problem will be resolved.
Please rate my answer
Sep 09, 2009 | Canon BubbleJet i560 InkJet Printer
Officejet H470
go back to hp's driver download page for your printer and download the "full featured" suite driver and software. The toolbox is included..
May 29, 2009 | HP Hewlett Packard Officejet H470wbt...
Cannot align print cartidge on HP PSC 1315
i have the same problem. i think mine centers around the fact that i refuse to spend the money to buy a color cartridge. i believe the alignment sheet must be in full color.
i did find a very strange solution to preventing the alignment page from printing, but i haven't tried it yet. http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-and/Alignment-Page-HP-PSC1315-prints-every-time-printer-is-turned-on/m-p/224243
not a solution, but it might help...
Dec 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
Officejet H470
Go to start >All Programs. See if you have a HP folder , hold you mouse over it and when the drop down windows appears, selet HP toolbox. There you will see the alignment function there.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 25, 2008 | HP Hewlett Packard Officejet H470wbt...
Manual to repair
HP OfficeJet pro 8630 is out of alignment when you see the "alignment failed" message. Printer alignment web pages should be exact for obtaining accurate Prints.
Stay tuned regarding more updates, on boosting your HP printing activities. You can also visit our website 123.HP.com/ojpro and more guidelines will be provided to you for resolving the Printer alignment errors
To rectify the previously mentioned error:
    ·Try aligning your current HP OfficeJet pro 8630 ink cartridges by resetting the printer.
    ·You can also align, by using a diverse type of paper.
    ·If you have inserted fresh cartridges, it is the mandatory to check some alignment pages.
    ·This specific issue also occurs, if you have not tested the sample alignment page.
    ·This alignment web page checks the accuracy of the alignment settings. When your HP OfficeJet professional 8630 won't print, verify the leading cartridge access door.
    ·If this door is not closed properly, it could cause this issue.
    ·After checking the access door, decide if the alignment web page prints automatically.
    ·If it effectively prints, you can complete this process. If it doesn't print, search for the troubleshooting mechanism below.
    How to set the HEWLETT PACKARD OfficeJet pro 8630 print alignment issues by visiting our website 123-HP-com-ojpro. com
      ·Look into the printer carriage for any obstructions.
      ·The obstructions occur due to improper packing materials, improper position of cartridges etc.
      ·Try reinstalling the cartridges to ensure that the Printing process is accurate.
      ·Do not touch the nozzle, as this might damage your Printer.
      ·Tri-color cartridges can be slid into the left slot and the black or image cartridge has to be inserted into the right slot.
      ·A printer reset can solve this issue. Detach the Power cord from the printer device, without changing the printer system.
      Give a minimum holding out period of 30 seconds. We have a great team to provide you fantastic troubleshooting guidance or visit us all at 123-HP-com-ojpro. com or call us @ +1-855-718-4110.
Jun 04, 2008 | HP Photosmart 375 InkJet Printer
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Computers & Internet Logo
310 people viewed this question
David Payne
David Payne
