Canon mp390 error code on printer ##343
Hi i am getting error code ##343 on my cannon mp390 ...when i open the scanner to reload the ink tank ... the ink tank does not react ....
  • 6 Answers
SOURCE: CANON MP730 ERROR MESSAGE 343 WASTE INK FULL
1-press the "menu" key
2-press the"copy" key
3-press the"#" key
scroll thru the menu heading until you come to "counter"
press "ok"
press "menu"
and select "clear all" it will ask you to "please wait"
then press menu two times
restart your printer
it will work
Posted on Mar 14, 2008
SOURCE: Canon Smart base MPC 600 F - Error 343
cookies
Posted on Apr 29, 2008
  • 81 Answers
SOURCE: Error U130 Cannon ink tank
it is possible that the ink chip is damage. try to buy another. or you can buy original ink to make sure the printer is ok.
Posted on Jun 13, 2008
SOURCE: cannon MP390
In the end, folks, I decided to pitch the machine altogether. And Canon gave me a great price break (free shipping, discount, etc.) because they had my original serial number on their records ... I have a new MX310 (multi-function - faxes, scans, prints, copies color and black and white) and I'm very happy with it. Easy to use and does the trick.
I did decide, though, to stop printing photos from this machine. It uses up too much ink. Better to just go to CVS or a photo store and have them do the deed on better paper and use their ink. Occasionally I print cards with pix on them, or a 4x6, but not a slew. And it's so nice having this machine in the house, when I don't work anymore in an office where you could do all that stuff if need be.
Posted on Aug 09, 2008
SOURCE: Cannon printer MultiPass.MP390 waste ink
1)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
Posted on Dec 01, 2008
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MP36 error ##343
The error code means "Ink Detection Waste Ink Tank Full". This means that the ink pad needs to be replaced. Also, dont forget to set the eepron counter to 0. Please follow the steps:
Press
ADITIONAL FUNCTIONS
SCAN
COPY
SCAN
scroll to TESTMODE
scroll to PRINTER TEST
scroll to EEPROM CLEAR
and the press the numeric key 3 or and keys.
Select INK COUNT, and then press the
numeric key 0 or and keys to reset the waste ink capacity.
Press the [Stop/Reset] key and then the
[ON/OFF] key to end the test mode.
I tries to replicate this error in my printer and I was able to aolve it with the above mentioned steps.
Hope this helps!
Rehards,
HP
Aug 28, 2009 | Canon SmartBase MP360 All-In-One InkJet...
What does the trouble code on a cannon printer
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Thanks.................
Jul 17, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Canon Multipass390 Waste Ink Tank near full
Have a look here
http://resetters.blogspot.com/2009/04/reset-waste-ink-tank-canon-mp390-and.html
Apr 29, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
'Waste ink tank near full' Canon MP390
Hey there DrKeith
Click here for a page with a better solution than canon provides. You'll have to scroll to the bottom. But there is all sorts of useful info on the way down. So if you have the time, some of it may be useful to you also.
The procedure described resets the counters. It is detailed, easy to follow and much less expensive.
If you run into a problem, hit that ask button again. No worries.
Have a great day
Mike
Sep 17, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Canon smartbase Mp 390 ##343 Check printer
can you help my printer canon smartbase mp390 not working gives notice check printer ##343
Jul 25, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Error ##343 and it didn't print anything Orange light below screen has been flashing, screen message "Waste Ink Nearly Full". No idea where waste ink container is kept? Have changed cartridges. Now saying...
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
hope it helps
cheers
Jun 09, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Cannon MP390
Feb 12, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Error code ##343
We have just attempted to install an Cannon imageclass mp360 and the error message "check printer ##343" is displayed.
Can you please help.
May 14, 2007 | Canon SmartBase MP360 All-In-One InkJet...
357 people viewed this question
jasbo
jasbo
