Question about Blanco Sink Waste Strainer / Stopper BDSSSB
Do i need to use plumbers putty with the blanco strainer and silgranit sink
  • 43,501 Answers
No I use a small bead of clear silicone... if any squeezes out just let it bead and set up ...after it dries just trim it off with a sharp knife...
works great!!! and looks even better ...
heatman101
Posted on Sep 08, 2010
Leak at new strainer waste fitting
Did you put the rubber gasket and cardboard sleeve on the bottom of the sink(next to the nut and did you use plumbers putty on the top part of the sink under the top section of the basket. Hint if you put some soap on the gasket under the sink between it and the nut it will be easier to tighten also you must secure the top part of the basket as you turn the nut if not the plumbers putty will not seal. If you do not have the strainer basket holding tool wrench you can substitute with a pare of needle nose pliers. Large channel locks or pliers can work to turn the large nut on bottom. If you can recruit a helper to hold the top part of the strainer basket with the needle nose pliers it make the job of tightening the large nut easier. When a large amount of the plumbers putty has squeezed out and the strainer is flush with the sink you should have a tight seal.
Feb 24, 2012 | Blanco Plumbing
I am installing a Blanco cafe brown sink basket strainer. The directions state that a thin bead of silicone, not plumber putty, goes at the bottom of the sink hole. Is this accurate?
Yes The Blanko is installed with silicon not plumber putty. This is common with the newer sink strainers
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 15, 2011 | Blanco Sink Waste Strainer / Stopper...
I installed a black granite sink, but the BASKET STRAINER is leaking. Do I need to buy a specific Basket Strainer for the Granite sink and take model # of the sink.Or can i just buy any basket...
Hello.
You shouldn't need a special strainer.
Where the strainer meets the sink surface, ( the lip of the strainer ), should have plumber's putty.
Take a chunk of plumbers putty and roll it out like a snake and then stick it under the lip of the srainer all the way around. Set the strainer in the hole and then on the bottom side add the rubber seal, then the cardboard, or metal glide ring and then the nut.
As you tighten the nut it will squeeze out the excess putty and allow you to remove it.
1. Sometimes people try to use the rubber seal on the top side of the sink, but it goes on under the sink.
2. The cardboard/metal glide ring prevents the nut from tearing up the rubber seal so you can really tighten it.
I hope this helps you!
Thanks, Donnie
Mar 25, 2011 | Franke Kindred DP2233/90/1 Granite Double...
Do you use plummers puddy on silgranit to seal drain stop apparatus to sink or will tightening pressure seal the unit.
1) I suggest contacting seller of silgranit and then posting their reply to this thread to help others with same question.
2) Another thread on silgranit says NO plumbers putty
Posts say: use silicone.
http://ths.gardenweb.com/forums/load/kitchbath/msg0320464213692.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 18, 2011 | Blanco Sink Waste Strainer / Stopper...
What is the proper way to install a BLANCO sink strainer Kitchen Sink COD.100113 I believe is the code # Thank you
Hello, W/D here.
To install your strainer, you'll need some plumber's putty. The old one is removed by loosening the large ring on the underside and the strainer pulls out from the sink side. Once you are down to just the hole in the sink, you're ready to install the new strainer.
Get a portion of the plumber's putty in your hand about the size of a golf ball. divide it into two portions. Take one part, and roll it in between your hands, palms together and vertical, making a rope.
Take your rope, and place it around the sink hole. If you need more putty, roll the other portion in a similar fashion, and continue around the hole. You may need to overlap the rope putty where it's thin and at the ends to make sure that you get a good seal when you apply pressure the the basket. Place the strainer basket in the hole and press it down lightly, just enough to hold it in place. From under the sink, place the gaskets on the threads, followed by yjr large ring nut that will hold it all in place. Usually, there are two gaskets, a paper type, and a plastic type. Put the paper one on first, followed by the plastic, then the nut. Screw the nut down, applying some pressure to the strainer and plumber's putty. Adjust the strainer now, centering it in the depression in the bottom of the sink. Continue tightening the ring nut, pulling the strainer down into the sink, and squeezing the plumber's putty out, making a seal. Get it pretty snug, and wait a minute. The putty will continue to settle in the seal, and you will be able to tighten it some more after it does. Do this several times, and you'll end up with a good seal that will last. Take a regular screwdriver, and trace it around the strainer on the sink side to release the excess putty. You can ball it up, and press it back into the tub of putty, ready for the next time.
Best regards, --W/D--
Feb 09, 2011 | Blanco Sink Waste Strainer / Stopper...
We purchased a Silgranit sink and the recommended stopper-strainer (model no. 441098). Our plumber says that this unit is designed to fit through the sink bowl and attach to a waste disposal system (ie....
SILGRANIT II COORDINATED SINK WASTE DISPOSER STOPPER & STRAINER UNIT Fits disposer with 3-3/8" inside diameter only. It should just snap into the insinkerator sink flange.
Jan 17, 2011 | Blanco Sink Waste Strainer / Stopper...
Two rubber gaskets and a fiber gasket came with new strainer. do i use all the gaskets? what about plumbers putty
You are attaching sink strainer to sink opening.
1) Use plumber's putty. Finger-size roll of plumbers putty is applied around opening from top, or applied to the bottom of strainer basket. (Some sinks require silicone. Do not use silicone unless required by the sink manufacturer.)
2) Sink strainer is pushed into the sink opening, making sure it is centered and level.
3) From below, the rubber gasket is applied first, and then the paper gasket is second, and then the basket locknut.
4) Tighten locknut very firmly.
5) Wipe away excess putty on bottom.
6) Push down stainer from top again, and tighten nut some more.
7) Wipe away excess putty around bottom and top.
8) The cardboard washer lets the locknut rotate easily.
Dec 18, 2010 | Moen 22036 Stone Stainless Steel Sink...
Use foam gasket on sink strainer along with plumber's putty?
Usually the gasket is not foam but black rubber. There may have been a piece of foam as packing to protect the stainless. You would apply the plumber's putty directly to the sink. Insert the strainer directly into the putty, compressing the putty. Under the sink, remove the excess putty that extruded through the opening. Apply the rubber gasket to the bottom of the sink, and then the nut (sometimes a "cup" and then the nut) .When the nut is tight, remove excess putty inside the sink. LEAKPROOF!
Jul 06, 2010 | Franke Strainer Basket Sink Hardware
Blanco Sink Waste Strainer / Stopper BDSSSB Logo
1,379 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
