Question about Viking Professional Series VUAR141
Coils are freezing up on our wine refrig how do i slove the problem
What are best dates to drink red wine?
There is no magic date. Just make sure to chill it for a hour before drinking. I know it sounds weird but that is how it is done. For white wine and it's been in the refrig. you need to let it sit a hour before drinking. Most folks drink white wine too cold and red wine too warm.
Sep 06, 2014 | Wine & Spirits
The unit is a Breezeaire wine cooler. The evaperator is freezing up.
MOST LIKELY A FREON LEAK ALMOST 90% OF UNITS WITH FREON LEAKS DEVELOP ICE BUILD UP ON THE FRONT COIL, AND AFTER A PERIOD OF TIME IT GOES AWAY AND THEN UNIT RUNS NON STOP GETTING WARMER AND WARMER TILL IT HITS ARROWND 70 T0 72 DEGREES.
Oct 02, 2010 | Breezaire WKL 4000 Wine Cooler
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My coils are freezing . i have replaced the heating elament and timer and its still freezing.
What timer did you replace ? Your refrig uses a control board , not a timer .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a defrost heater WR51X10055 not working or the defrost thermostat ( pt. number WR50X10068 ) not working . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off / on .
May 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a danby dwc283bls wine cooler that no longer cools, and the compressor gets warm (above normal) does it need to be recharged
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Apr 15, 2010 | Danby DWC283BLS Wine Cooler
Does not freeze there is frost on the first 3 to
the freezing tells me that the unit is working but something is blocking the airflow. It is either a fan not pushing air over the coils or it is working and dirt is keeping it from blowing past the coils
Nov 25, 2009 | Refrigerators
Coils behind the freezer continue to "freeze up"
You have a problem in the defrost system There are three components: Defrost timer, defrost thermostst or terminator, and defrost heater. One of them has failed which is causing the evaporator to ice.
Apr 09, 2009 | Refrigerators
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Danby wine refrig
THE LAST THING THAT EVER HAPPENS IS FREON LOSS.
SO TRY THIS FIRST ...
LET THE COOLER STAND WITH "NO POWER FOR 24 HRS.
MAKE SURE IT INSIDE AT ROOM TEMP. NO HIGHER THAN 75 deg. AFTER THE ALOTTED TIME TURN THE T-STAT-"OFF" AND TURN THE POWER "ON" ...
THE CONDENSER FAN SHOULD START IMMEDIATELY. NOW LISTEN REAL CAREFULLY BY THE COMPRESSOR TO HEAR ANY CLICK NOISE. IF YOU DO THAT IS THE EXTERNAL OVERLOAD ( bI-METAL SAFTEY T-STAT THAT PROTECTS THE COMPRESSOR. TURN POWER OFF AGAIN AND DO THE FOLLOWING.
THERE IS : 1) A START (plug-in) RELAY THAT PLUGS INTO THE COMPRESSOR.
2) THERE IS A START ASSIST CAPACITOR MOUNTED USUALLY ON THE TOP OF THE COMPRESSOR TEREMINAL COVER.( THIS IS HELD ON WITH A METAL STRAP THAT CAN BE "POPED-OFF" WITH A SCREW DRIVER. OR IT MAY HAVE 2 MOUNTING SCREWS.
3) THERE IS A ROUND BI-METAL T-STAT THAT PROTECTS YOUR COMPRESSOR.(AS STATED ABOVE).
MAKE A DRAWING OF WHERE EVERY WIRE GOES AND THE DEVICES ON PAPER. .... THEN ... AND ONLY THEN REMOVE ALL 3 PARTS AND TAKE THEM TO YOUR LOCAL APPLIANCE REPAIR OUTLET. eg. APPLIANCE PARTS. APCO ETC.
THEY WILL CHECK ALL 3 COMPONENTS FOR YOU AND MOST ALL HAVE UNIVERSAL REPLACEMENTS FOR ALL 3 DEVICES NO MATTER WHAT BRAND YOU HAVE.... AND THEY SHOULD BE ABOUT $10-$15 EACH.
I HAVE REPAIRED HVAC & REFRIGERATION EQUIPMENT FOR OVER 40 YEARS. WHAT I DO IS REPLACE ALL 3 DEVICES. IF ONE IS BAD IT TENDS TO OVERHEAT THE OTHER COMPONENTS AND WEAKENS THEM.
NOTE: NEVER INSTALL REFRIGERANT SELFTAPPING VALVES TO CHECK FOR FREON ... A AMP DRAW WILL TELL YOU IF COMPRESSOR IS RUNNING AT FULL LOAD , AND AT THE EVAPORATOR YOU SHOULD HAVE A 10-20 DEG F. DROP IN TEMP. YOUR EVAP COIL SHOULD FORM A EVEN FROST ON IT IN ABOUT 2-3 HOURS.
THE MAIN THING IS TO ENSURE COMPRESSOR IS RUNNING.
IF YOU HAVE A THERMOMETER, THE LARGER COPPERLINE ON THE COMPRESSOR SHOULD BE ABOUT 50-60 DEG.AND EVENTUALLY WILL "SWEAT". THE SMALLER LINE SHOULD READ 120-150 DEG "AT THE COMPRESSOR" OUTLET CONNECTION.
MAKE SURE YOUR CONDENSOR AND EVAPORATOR COILS ARE BOTH ABSOLUTELY CLEAN. (CHECK WITH SMALL BRIGHT FLASH LIGHT TO SEE THROUGH COIL FINS.
THAT SHOULD SOLVE YOUR PROBLEM. YOU MAY FIND WHEN TAKING THE PARTS OFF ... A BROKEN OR BURNT WIRE. IF SO REPLACE IT WITH AT LEAST #12 STRANDED WIRE.
PROPER WIRE AND TERMINALS ARE AVAILABLE AT THE APPLIANCE PARTS STORE IN YOUR AREA.
GOOD LUCK ... JOE_REX
Oct 11, 2007 | Danby DWC283BLS Wine Cooler
Viking Professional Series VUAR141 Logo
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Joseph Hoffmann
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
