First Try to press the Door Alarm button for more than three seconds. This might reset the control.
If you don't have any results then you have a damage on the electronic Control Board which unfortunatly you need to replace and in a part that worth more $200.
Hello. begin by checking the water filter. It may be completely blocked and need to be changed. Then check the ice bin to make sure there is not a block of frozen cubes causing a jam. Nest, make sure the icemaker stop arm is down [the on position], then check the lock switch whic would prevent the dispenser from working. Make sure it is set to off. J.
I did all those things to no avail. The filter is just 3 months old. Again, the touch pad lights of water and ice do not light up. Similarly the temperatures can not be poked to go up or down (They are set at 0 and 38) Nor can the other buttons of Door Alarm, Temp Alarm, Max Temp, Humidity, Light, none of them are adjustable, although they do beep each time any of them are pushed. All this happened after dispensing two gallons of water.
