Question about HP Photosmart C6180 All-In-One InkJet Printer
Error code Oxc18a0101 HP all in one photosmart 3210
  • 567 Answers
To resolve this issue please follow these steps:
Disconnect the USB cable and remove the cartridges from the product.
Disconnect the power cord and wait for 30 seconds.
Reconnect the power and the cartridges.
Proceed to print a calibration page to test the Printer.
Reconnect the USB cable and try to print again.
In case this does not resolve the issue, please proceed to reset the printer by following these steps:
Hold the OK and the Help button at the same time.
While holding them down, plug the power in.
Continue to hold both buttons until the unit shuts off.
After shutting down, release both buttons and power on the printer.
This will resolve the issue you are facing.
I will look forward to your feedback and positive rating.
Posted on Sep 08, 2010
  • tallamerican Nov 21, 2010
    Your information was great and easy to follow, thanks!
  • wind_griffin
    wind_griffin Sep 08, 2012
    I followed your instructions but holding those buttons and then plugging the power in did nothing. The machine powered on as usual and did not shut down.
3 Suggested Answers
SOURCE: I have a ink system
Reset the product ->here's how
If this will not work ..then you need to replace the unit. ."Ink system failure" error oxc18ayyyy ,the unit can not be recovered.
Posted on Mar 26, 2011
pineworks
  • 4041 Answers
SOURCE: hp photosmart 3210 error oxc18a0206
Hi there
This is only some thing you can try it may work.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 13, 2010
Ink system failure error: 0xc18a0007
Look for your specific error. Click the link for reset if your error is not found:
HP Photosmart 3210 Ink System Error
Failing this, your 3210 may require repair service.
I hope you found this document helpful.
Dec 28, 2009 | HP Photosmart 3210 Printer
I have a Hp photoshop 3210 printer ink cartrage error empty or
I installed new cartriges, but my printer keeps giving me an error msg, Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: Oxc18a0206. What do I do now?
Nov 06, 2009 | HP Photosmart 3210 Printer
Printing error oxc18a0101
Try resetting the printer:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on.
Jul 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Photosmart 8180 has error message Oxc18a0101
try to follow this instructions to fix the error: Hit * and # at the same time on your printer, then enter code: 123 press right arrow, then go to system configuration and press ok 3x. unplug power from printer and wait 2 minutes, plug the printer again and then it will all be back to normal. hope this helps. Good Day!
Jul 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C8180 - Ink System Failure - Oxc18a0101
i had exactly this error message. Rang HP. They said it was a hardware failure, they couldn't fix over phone, would cost 2x cost of new printer to fix, but they offered me 20% discount on new printer if ordered over the phone.
But with some fiddling, problem now resolved. Here's what I did:
- press Red Eye Removal and Print Photos button together
- goes to Mfg Commands -> Enter Special Keys Combo. Press OK
- uaiux Support page (some code) -> click right arrow key until you get to System Configuration Menu - click oK
- should say hardware failure status - click OK
- says hardware failure status: Clear. Press OK to clear
- I clicked OK on this and system reset itself and problem was solved
Jun 24, 2009 | HP Photosmart C8180 InkJet Printer
I don't know how to find printer documentation on Error Oxc18a0101.
You need to reset the printer. Please follow the instructions in this link, and if that doesn't work, try this link.
If neither is successful, you may have to have the unit serviced, but usually one or the other method will get your printer back online.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 19, 2009 | HP Photosmart 3210 Printer
Oxc18a0101 error message - C6180 All-In-One
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plugthe power in. Continue to hold both buttons until the unit shut off.
Alternatively follow instructions on this document from HP.
Oct 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP 3210 failure code
Hi Pddunstan,
Please click on the web link given below and perform the steps as provided in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&cc=us&lc=en&dlc=en&product=439488
Else please chat with HP online technical support.
The chat support is free of cost, where you can chat with HP online technician.
http://ipgweb.cce.hp.com/ipgna/caller/chat.asp?dd=aio&productName=HP+Photosmart+3210+All-in-One&productCategory=421635&SCOID=238445&PSOID=439599&aoid=null&lang=en&cc=us
Have a great day!
Mar 09, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
634 people viewed this question
Seeker5211
Seeker5211
