Question about Mitsubishi WD-57731 57" Projection HDTV
My 57731 cycles through formats by itself. It goes from standard to wide expand and back again over and over. It stops after about 30 minutes.
    President:
  • 1,284 Answers
If there are any format buttons on the front of the TV make sure it doesn't appear to be stuck. Also there is a possibility that a button is sticking on the remote for your TV or cable box or satellite
Posted on Sep 08, 2010
Why does the scanner keep turning off after 30 minutes with a red light? We have to keep manually turning it off and on.
Some kodak of the i2000 series abide by different energy conservation standards. You can increase both power off \ sleep settings to 240 (4 hours), maximum. Unfortunately when the newer energy conserv's go have to be power cycled to resurrect. I have a tiny text script I can send that will make the 2400 never turn off I'm just not around my PC right now. Stay tuned!
Oct 20, 2014 | Kodak i2400 - document scanner
Machine grinds and grinds but never brews
Want serial number and activation code of mavis beacon deluxe 17
Dec 09, 2013 | Saeco Vienna De Luxe Espresso Machine
Emerson 32 HDTV LCD...my picture is smaller than the screen. How do I make the picture fit the screen. I'm missing a few inches of the images on both side...?
Most Emerson remote controls have a "FORMAT" button. Each button press cycles through TV Screen aspect ratio choices, such as Normal, Movie Expand, Wide, Zoom, etc. Pick one that fills your screen. You will probably have to change this setting again, depending on the signal source or channel selected.
The button cycles through the choices in a loop, so you can always get back to Normal.
Mar 24, 2013 | Televison & Video
Continues to go out of balance
The stainless steel bowl has lost its ballast water & goes out of balance,Replace faulty bowl.
Oct 03, 2012 | Fisher Paykel Fisher & Paykel AquaSmart...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Format Change
there may be a setting in the menu that you have to turn off to stop this
Jul 21, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi wd 57731 wont power up
There is a lamp cover on the back that only requires a few screws to remove. the lamp is behine there, you will need a standard screwdriver to remove the lamp and inspect it. If indeed the lamp is bad you will see it shattered and/or burned at the tip. The timer light flashing for 30 seconds is normal as the TV is going thorugh a boot up process. One word of advise, don't touch the glass part of the lamp pnly the case.
Nov 26, 2007 | Mitsubishi WD-57731 57" Projection HDTV
Quick Wash cycle restarting
Aestaie, On the quick wash cycle the machine goes through a heated rinse at 160 degrees. I think what's happening here is that the board checks the thermistor and is finding that the water is not hot enough and say's, hey, I need more time to heat this water and resets itself. The element in the dishwasher will only heat the water 1 degree every 3 to 5 minutes. So after the initial wash, there is a 2 minute drain, it fills again and there is the heated rinse. If the water is 120 and the final rinse needs to be 160, we have some heating to do here. Therefore the reset. Sounds like the dishwasher is working OK, Catriver..post back
Apr 24, 2007 | Maytag MDB9600A Jetclean II Built-in...
Mitsubishi WD-57731 57" Projection HDTV Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
