Question about HP LaserJet 4350 Printer
Is the HP R73-5048 4200 4300 Series Envelope Feeder Tray N279 able to be used on the HP 4350 dtn? If so, where does it attach to be utilized. I'm considering it, depending on reliability and quality.
  • 141 Answers
SOURCE: HP laserjet 4350 DTN Folding corners
teflon coating on heat roller in fuser is coming apart. replace the fuser. also check to make sure the paper tray is set to the correct size. this means pull the tray out, remove all paper, look inside to make sure the arrow is pointing directly at the correct media size you are using i.e. letter or legal or whatever you are using. Good Luck! please rate this carefully.
Posted on Oct 11, 2008
SOURCE: how do i double side print with an hp 4200 dtn
Try to see step 10 here , the last step -
http://polisci.stanford.edu/psgsa/printer/xp.htm
...set duplex unit to be installed...then it will showed up in General, Printing Preference
Posted on May 27, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
ArgusFixer
  • 51 Answers
SOURCE: My Laserjet 4200 dtn with Envelope Feeder is
Sounds like you have a bad fuser. Are you using refilled 3rd party toner or genuine HP toner?
measure the distance from first instance of the repeated image to the next instance on same page. This will identify if the image is stuck on a fuser roller or the toner's photoconductive drum.
each roller in a printer has a different circumference and repetitive images can be diagnosed this way.
provide the measurements as close as possible in fractions of inches or cm's.
Thank you,
Posted on Feb 11, 2010
SOURCE: for the HP 4350 laserjet
You need to replace the fuser lamp (or ceramic fuser) and the thermistor.
If you can get the replacement parts, it's an easy fix.
Posted on Nov 17, 2010
Hp laserjet 4300 dtn tray one pickup
Yes,
Adding the duplex attachment makes the TN a DTN nothing different in the firmware of the printer.
Feb 05, 2013 | HP LASERJET 4300DTN Q2434A LASER PRINTER...
HP Laserjet 4200 with optional Envelope Feeder will not automatically pull #10 envelopes from Envelope Feeder?
Use a damp lint free cloth and clean the feeder rollers.
Print out a configuration page to make sure that the printer recognizes that the feeder is installed.
Usually the envelope feeder problems stem from age and/or dirty rollers.
Make sure that your software app sees that the feeder is attached.
Feb 08, 2011 | HP LaserJet 4200 Printer
How do you switch default from tray 1 to tray 2
To print by type and size from tray 2, the optional trays, or the optional envelope feeder, you
might have to to unload tray 1 and close it, or set TRAY 1 TYPE and TRAY 1 SIZE to types
other than ANY on the PAPER HANDLING menu at the printer control panel. For more
information, see Customizing tray 1 operation. Settings in a program or the printer driver
override control-panel settings. (Program settings generally override printer-driver settings.)
Here is the manual:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 07, 2010 | HP LaserJet 4350 Printer
I have an envelope feeder that came with my old LaserJet 4 many years ago. I replaced the LJ 4 with an LJ 4-Plus and tried to use the envelope feeder on it. I get an immediate error message "EE...
My suspiction is there is a tab on the tray that triggers a switch telling the printer what type of tray has been inserted. Your old tray is likely different from the Plus 4 tray and the printer knows it.
Jun 04, 2010 | HP LaserJet 4 plus Printer
Jan 05, 2010 | HP LaserJet 4350dtn Printer
How do I install the envelope feeder tray on the HP 4050n printer I have the feeder tray but no instructions to put it in. thank you
As long as you have the correct envelope feeder then it just locks into place on the front of the printer. Simply open the tray 1 feed door (the one with the model number 4050 on it) and your envelope feeder just "locks" in just above the open tray. If you look at the printer you will see a small square connector block. Now look at the envelope feeder and you will see where the 2 meet together. Then match up the 2 and "lock" it in place.
Dec 08, 2009 | HP LaserJet 4050n Printer
4250 HP. Loses settings. Correct to show envelope
In the paper-handling menu set the envelope feeder size to the size of your envelope and the envelope feeder type to *any type.
Then ensure you are printing envelopes from your application.
Nov 25, 2009 | HP LaserJet 4350 Printer
Oct 09, 2008 | HP LaserJet 4350dtn Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
682 people viewed this question
Seeker5211
Seeker5211
