Question about Poulan Garden
Poulan pro 295 no oil to chain - Poulan Garden
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 67 Answers
On the left side of the saw, there are two black round taps. One for oil, one for fuel. Most likely the front tap, is your oil filler. Check and refill. If already done it, then you need to dismantle your blade and clean the area around the axle of the engine to get a clean oil exit.
Posted on Sep 08, 2010
What is the file size (to sharpen chain) for a Poulan Pro 295 46cc?
I am pretty sure this machine ran a .325 pitch chain, so the file size is 3/16, if it is running 3/8 low profile chain ( 91 ) it will be a 5/32 file, the pitch should be marked on the bar .
Sep 16, 2011 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan 295. I needed to replace the chain. It is a 20" chain. There is bar oil in the resevoir. The chain will not stay on the bar (it seems loose even when fully tightened). I replaced...
If you replaced the bar AND the chain, you'll need to make sure the chain is the correct chain for the particular bar you've used. If you're only replacing the chain, you need to make sure the chain has the same # of drive links as your old chain (maybe one or two more, if you've had some removed because of chain stretch).
On that particular model, for a 20" chain, you could have a 78 OR 80 drive link chain (drive links being the part of the chain that rides in the groove of the bar). The correct drive link count is determined by the bar you've installed and should have been made clear by whoever you purchased the bar from. Some brands use an 80 drive link chain, but MOST use the 78 drive link chain.
If the bar you purchased uses the 78 drive link chain, but you have an 80 drive link chain, then no matter how far out you adjust the bar, you may not get the chain tight enough. PartsBuggy shows a listing of which bars use the 78 drive link chains here.
Aug 29, 2011 | Poulan Pro Chain Saw 46cc 20"
Gas oil mix for old poulan 295
The gas/oil mix is at a ratio of 40 parts gasoline to one part oil. Please rate my solution. Thanks!
Jan 30, 2011 | Poulan Pro Chain Saw 46cc 20"
Chain wont tighten up for Poulan 295 Pro chain saw
hi after awhile chains stretch, make sure they get oiled good. nut that holds bar must be lose, like a 1/2 turn then you can tighten screw . don't over tighten ether of these. it takes time to find your saws happy spot , so be patient and keep trying to tweak it tell ya find it..vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
Jul 18, 2010 | Poulan Pro Chain Saw 46cc 20"
What is the correct gas/oil mix for the Poulan Pro 295 chainsaw?
50:1 according to this:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c2b3efd6af050e6b88256f77001bfbdd?OpenDocument
I suspect the manual says 40:1, but if properly adjusted it will operate better on 50:1.
I gallon of premium fuel to 2.6 ounces of quality 2-cycle oil = 50:1.
I gallon of premium fuel to 3.2 ounces of quality 2-cycle oil = 40:1.
HTH David;
Lou
Feb 10, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need bar and chain for 20" poulan pro 295
Find what you need here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Oregon numbers can easily be located with a Internet search and convert easily to other manufacturers numbers.
Chains can be fabricated locally in a few minutes (take existing chain for use as a pattern).
HTH
Lou
Jan 18, 2010 | Poulan Pro Chain Saw 46cc 20"
How to install/remove feul pump on a Poulan 295 pro, is it from the Tank side, or the worm screw side? I am familiar with the saw, just not this part of it, and I am fearful of just trying to pry it out...
Are you referring to the oil pump? If so start by removing the clutch and drum.Then there are 2 philips screws that hold on the oil pump.The gear is plactic and wears from the slightest bit of dirt. The entire oil pump assembly is inexpensive and should be replaced.
Dec 06, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain Lube Leak
It is the nature of the beast. Many chainsaws suffer from this malady. I own a bunch.
Lou
Try loosening the oil cap prior to bed.
Aug 04, 2009 | Poulan Pro Chain Saw 46cc 20"
POULAN PRO 295: RUNNING VERY STRONG, FOR OVER AN
Remove the air filter, squirt a little fuel into the carb. Start and let run if it will for a few minutes. Could be you had some water in old fuel. and it is still in the intake of saw. If it still will not run after squirting some fuel into carb. You have a firing problem.
Apr 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
118 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
