Question about Onkyo Audio Players & Recorders
The problem of my receiver is that the center,surround speaker is not working no sound is comeing out from there its only working the front speakes what can i do my reciever is onkyo tx-sr500 (AV RECIEVER TX-SR500) Thank you for your help
  • Onkyo Master
  • 736 Answers
You get sound out of the center speaker depending on what you have connected to the receiver and with what cables, what type of signal is being fed to the receiver, and what settings are available on whatever is connected to the receiver.
Let me paint you a picture. You can connect a television to an Xbox with an hdmi cable. Then you connect the Onkyo to the television with a fiber optic cable. The sound coming from the television depending on the television--the signal that is being fed to the receiver is normally "watered down" and therefore you will not get sound out of more than two of your speakers. If you connect the Xbox or whatever to the receiver directly with a fiber optic cable or even better if you have hdmi outputs on your device and connect it to the receiver with an hdmi cable AND you have the device set to output bitstream audio THEN you will be able to get sound out of all of your speakers depending on what the device is outputting i.e. dolby 5.1, 7.1, true hd and etc.
Posted on Sep 08, 2010
No surround sound
firstly Jessica you will need either a cd or some form of media that is recorded in surround sound then make sure all wiring is in it's right sockets then while your "cd" is playing configure the amplifier. I hope this will be of some help goodluck.
Nov 26, 2013 | Yamaha RX-V373 5.1 AV Home Theater...
I don't know how to get all speakers to work
Sounds like your surround settings are not correct. Try selecting a prologic surround mode and see if that turns on all speakers for you.
Dec 26, 2012 | Kenwood VR-207 Receiver
I cannot get my new center speaker to work???
Hi on a Denon receiver you generally have to do two things. By entering the on-screen setup go to speaker setup and select the center speaker and surround speakers if you have them. Depending on the age of the receiver it will ask you to select between yes or no (on or off) or none, small or large.
(most centers are considered small unless they have 5" or larger mid-bass drivers)
Next you will have to select a mode that activates the surround sound mode usually Dolby but many have alternates such as Neo, theater etc..
This should activate the center channel, you will need to then adjust it using the "Tone generator" or the Audessy setup program.
The goal is to have the same amount of sound coming from your front three speakers.
Hope that helps
Jan 02, 2010 | Denon AVR-3300 Receiver
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Apr 14, 2009 | Yamaha HTR-5730 Receiver
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
67 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
