Question about Panasonic Viera TH-42PZ80U Plasma TV
Black 2inch line going down right side of screen
    Scholar:
  • 30 Answers
Hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Posted on Oct 30, 2010
I own a LG50PG30 that once the TV becomes warm, develops a 2inch black vertical line through the right side of the screenfacing the TV which contains a 1.5inch white line through it and has multiple c
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 05, 2015 | LG Televison & Video
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
LG 50PG20 Plasma,, nothing shows on screen its all black
This model was known for issues with the Y-sustain, Y-drives, and the Z-sustain boards. These boards help process the picture image to the screen.
When one or more of these boards fail, the screen stays black, and you only have audio & on/off.
You could call LG and try to get your TV repaired at a discount if you can convince LG to honor this known issue.
Another issue could be the actual panel has gone bad. The plasma panel in your TV has a two warranty and LG would fix that for free. Well…it would be free as long as it’s not past two years of your date of purchase.
What zip code are you in?
Jun 18, 2010 | LG 50PG20 50 in. Plasma HDTV
Green line 2inch appeared on left hand edge next
look like you panel fail,
but you can get 2nd opinon
Jan 08, 2010 | Televison & Video
E machines flat computer screen began blinking and having colored lines going through it after turning black. By odd mishap I realized when I pressed on the screen it stopped doing that. That has been...
By the way, is it an LCD screen? I guess so. LCDs have small IC's either on the lower portion or in the left side of the screen. When these become loose, the tendency is to have vertical or horizontal lines on the screen. Hot air blower might solve the problem. But most will not. Better claim warranty or replace the unit.
Dec 07, 2009 | E-Machines eMachines Desktop PC
Black line down right side of screen
turn off laptop.
press and hold on the D then press Power button.
during the LCD BIST test check if the black line down right side of the screen is visible. if yes LCD needs to be replaced. if not connect your laptop to an external monitor check if the black line display appears to the ext monitor, if yes uninstall / reinstall video driver if fails replace video card or if it is built in replace motherboard.
if no ext monitor available then run PSA (press and hold Fn key then press Power button)
check if the black line is visible. Check also in BIOS is black line is visible, if yes then uninstall reinstall first the video driver if fails replace LCD.
Oct 11, 2009 | Dell Inspiron 9200 Notebook
My Vizio Plazma 42in hdtv has a 2inch red verticle stripe on the left side and now the right side of the screen. It is a 4 year old 2400 dollar set I go at Costco.
Hello
This is most likely being caused by capacitors in the power supply changing value. Take it to a reputable repair person.
Good luck
Sep 23, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
There is a black 2 1/2inch bar on leftside of screen how do i adjust is?
if your lucky it's just your H-center is off tilt. to check this Press the menu button on your monitor. scroll through the options till you see Horizontal-center option. select this setting and move the screen to the left. The entire screen should start shifting to the left and fill in the screen. now if you do this and you get a black bar on the right. Center the screen where you have the same amount of black on both sides of the screen. scroll through your menu till you see the H-size. increasing this will fill in the black area. Hope this helps.
Sep 13, 2009 | X2Gen MG19MY 19" LCD Monitor
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
Dec 10, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Panasonic Viera TH-42PZ80U Plasma TV Logo
220 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
