Question about Dell Precision Workstation 490 - DT - 64 BIT Dual Core Intel Xeon Processor 5110 1.6... PC Desktop
Dell precision 490 dual Xeon cmos isnt booting case fan is overspeeding
5 Suggested Answers
SOURCE: Dell Precision 490 constant reboot after ghost image completed
Ok thank you for the update.we are always here to help if the need arises.richardm69
Posted on Dec 02, 2008
  • 3940 Answers
SOURCE: dell precision 490 led 1 & 3 blinking
The 2nd link here should be helpful
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Generally, this is a RAM issue
Posted on Apr 18, 2010
  • 5346 Answers
SOURCE: Computer won't boot - there's a flashing 1 and 3
Either the power supply has failed or the power cable is not getting power to the board (if the lights are amber). Check that the power cable from the power supply to the motherboard is fully seated. You may need to replace the power supply - you will need one that will fit your case and matches the various devices and plugs that you currently have. (20+4 pin for the motherboard gives the most flexibility, additional power for the CPU (4 pin or 8 pin), SATA if you have SATA devices, regular 4 pin peripherals for IDE hard drives and optical drives, 4 pin floppy, video card (if you have a PCIe card that needs a 6 pin plug), etc.)
I hope this helps.
Posted on Jul 13, 2010
Power supply dell precision 490
I would recommend a 500Watt power supply, they are around 30 pounds and can be bought from any PC supplier.
May 04, 2014 | Dell Precision Workstation 490 - MT -...
How can I fix DELL precision 490 issue
Ersin, not knowing the age of the unit and the motherboard condition, is hard to make a problem fix.
If the unit is two or more years old, I would examine the motherboard for Bad Capacitors.
If the caps are not crowned or bloated, try the next step.
Remove all external devices and check the fallowing.
USB Ports for shorts
CMOS Battery for 3.0 volts
Remove and reseat the memory and CPU ( Reseal with Thermal )
Check all your cooling fans
Remove and test the power supply. ( Do this First )
When testing the unit, make sure all external devices are disconnected.
Hope this helps.
Apr 29, 2014 | Dell Precision 490 Workstation Xeon...
Dell 490 Unable to initialize Fan Controller
This issue can be resolved by disconnecting the AC power cable from the system and draining the power from the system by pressing and holding the power button on the front of the chassis. (Approximately 30 seconds). Reconnect the AC Power cord and restart the system, issue should be resolved
link
http://stuartconnections.com/products/Computers/Systems/Desktops/Dell/Precision_690/Users_Guide/tools.htm#wp1056136
Jan 22, 2013 | Dell Precision Workstation 490 - MT -...
Dell precision 490 led 4 remains on
try to clean the memory slot of your computer as well as the memory module then power up your PC. just do hardware maintenance by means of cleaning all any dust inside the computer. Hope it helps thanks.
Nov 02, 2011 | Dell Precision Workstation 490 - MT -...
Dell precision 490 led 1 & 4 on
If you are getting no video at all, then we can use the diagnostic LEDs and the power LED to help determine the failure.
Mar 29, 2010 | Dell Precision Workstation 490 - MT -...
System will boot then shutdown. Have to unplug
try your fan on your computer chip it may be plugged or not turning and heating up and turning off, pull one side off so you can see for sure that is the most common problem for computers to do that. Hope this helps write back if that's not it and thanks for using fix-ya
Jan 19, 2010 | Dell Precision Workstation 490 - MT -...
Hello-
I figured out how to ghost a Dell Precision 490 with a 32 bit Windows XP Image! Like you I had the same problem where it would constantly reboot after I imaged it with an existing 490 image. The answer is actually very simple. Boot up your Precision 490 and hit F2 to enter the bios. Select Drives and then SATA Operation, change it to "Raid Autodetect / ATA". Reboot the 490 and re image the machine, it will now work!
Dec 01, 2008 | Dell Precision Workstation 490 - MT -...
Dell Precision Workstation 490 - DT - 64 BIT Dual Core Intel Xeon Processor 5110 1.6... PC Desktop Logo
162 people viewed this question
Alun Cox
