Question about Whirlpool GB2SHKRLS Stainless Steel Bottom Freezer Refrigerator
GB2SHKXLQ01. makes a loud hum about every 3 min.then a click. sounds like a switch trying to make contact. still running, but concerned it is compressor switch.
  • Whirlpool Master
  • 3,361 Answers
The start relay on the compressor is going bad and must be changed out before you have no cooling at all.
Posted on Sep 08, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My GDM-12 is not cooling. when I turn the temp up it make a loud humming sound.
If the humming last 3-5 seconds then makes a faint click sound and stops humming for a minute or two. Then resumes the hum again it may be your compressor locked down. Stuck. Most likely it is just a bad start capacitor not kick starting the compressor. A $6 part.
Mar 07, 2014 | True GDM-12 Refrigerator Commercial
Dryer stops
If the hum is loud I would suspect something is jammed and the motor is stopped leading to a heavy current running through the motor. After 5 or 10 minutes I would anticipate the circuit breaker would trip or the motor would burn up. If the humming suddenly stops then a thermal overload switch might be activating and when it cools down normal operation resumes. This is my only insight.
Jun 08, 2013 | Kenmore 73952 Gas Dryer
I have dryer lgr3624eq1 when you push the start button it makes aloud humming sound and wont start but if you wait 2 hour it will start but it will shut off before the full time
We're sorry to learn of your experience. We recommend service for a proper diagnosis. If further assistance is needed, please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with the website you reached out to us on (fixya), brief description of your concern, your name, address, a phone number and best time to reach you along with your model and serial number.
Jan 17, 2018 | Whirlpool LGR3624JQ Gas Dryer
My microwave has stop heating up food. What is the cause?
There are several things that can cause this:
1. Bad high power diode failure (most common and usually causes a loud humming sound when it fails initially then never heats again)
2. Bad capacitor (open or shorted)
3. Stuck Magnetron oscillator (Makes a loud humming sound when the Diode and capacitor are known to be good.) / Magnetorn failure
4. Door interlock safety switch failure. (You should hear 3 clicks on most microwaves as the door just opens or closes... if your microwave light does not come on when the door is opened you only have 2 micro-switches and only hear 2 switch clicks.
5, Main control board relay failure / main board failure.
Those are the most common reasons listed in order of usual failures. Each one of the above possible failures has a different troubleshooting procedure.
Thanks for choosing FixYa,
Kelly
Sep 21, 2011 | Heating & Cooling
I have a kenmore dryer, recently it has started to be loud, on start up and has a loud hum when running. It runs for 20 min and turns off. If you try to restart it just hums. if you wait about 30-45 min it...
It is possible the belt has come off the the tensioner pulley, or the pulley itself has locked up and is putting a strain on the motor making it run hot and tripping the thermal overload. Either that or the motor is getting weak and needs to be replaced.
Dec 28, 2009 | Kenmore Dryers
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Loud humming
vibration,,there a screw missing some where
Aug 28, 2008 | Estate TGDS840JQ Gas Dryer
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Whirlpool GB2SHKRLS Stainless Steel Bottom Freezer Refrigerator Logo
63 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
