Question about LG LMVM1935 Convection/Microwave Oven
Black LG microwave oven, fail light bulb inside, I don't see any outside panel to open, there is one inside where bulb exist,but i don't see any screws there can i open that or not? where can i buy this bulb?
  • 3 Answers
The oven lamp is accessible when the whole outside cover of the oven is removed. The lamps these days are a special bulb and would be available from a TV repair place or a appliance repair centre.Take the old lamp in with you to pbtain the correct part.
Posted on Oct 16, 2010
CANT FIND LIGHT TO CHANGE IT
Changing bulbs on microwave ovens is usually from the outside of the cabinet. You will find a small door in the location of the light, with either one or two screws. They are the only two screws that aren't security screws!
Apr 06, 2016 | LG MS-0744Y Microwave Oven
How do i gain access to the bulb to replace it?
I assume you're talking about the light that is inside the microwave & not the cook top light. Unplug unit. Normally your microwave will have a plastic or metal panel on the top front or back of the unit. (The bulb is not always changed from the inside of the unit.) Simply remove the few screws that hold the panel on & remove it. This should give you simple access to the bad bulb. Replace bulb then reassemble. Some free standing units require the entire outside enclosure be removed.
Mar 01, 2016 | Microwave Ovens
How do you change a light bulb in a panasonic 1100 microwave oven?
Some microwaves have a small panel on the side which you will need to undo a screw . Open the small panel and unscrew the bulb.
Others have a small square panel inside which may look like card that you can slide out and remove the bulb.
Mar 07, 2015 | Panasonic Microwave Ovens
LG LMVM2085SW 1100 Watts Microwave Oven--Outside downward lights both went out at the same time. All else seems to be working.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Let me know if I can help further.
Aug 29, 2012 | LG LMVM2085SW 1100 Watts Microwave Oven
How to change light bulb in microwave
Ensure the microwave is un-plugged.
The procedure differs depending on the microwave.
Some microwaves will have a glass panel covering the bulb which can be unclipped or unscrewed from the inside of the oven or there may be an access panel on the outside. On other ovens the complete outer shell has to be removed to get at the bulb. Bulbs can normally be unscrewed but sometimes you need to push and twist anti-clockwise to remove.
When you have replaced the bulb, ensure that all panels and screws are replaced securely.
Sep 05, 2011 | Microwave Ovens
Blown bulb for a LG microwave oven MS3448XRK what bulb and how do i change it?
Just opened mines today .... guide below is almost correct ....when you lift the cover off the bulb is shielded behind a metal box.... theres one screw that connects it to the magnotron .... take off that screw and pull out the plug with the brown and white cables that is connected to the bulb... the bulb is a T170 KEI 240v 25W on mines at least which no one around stocks so will just try and claim under warranty as 2 years labour 6 years parts... bulb has never worked just never got to opening it up ...bulb looked trashed when i took it off... element was all black and in bits rattling inside the microwave ... only use the thing for warming kids milk and sterilising bottles...
May 25, 2011 | LG LMV2053 Microwave Oven
INTERNAL LIGHT DOES NOT COME ON WHEN MICROWAVE IS OPENED OR WHEN RUNNING. I AM NOT SURE WHICH REPLACEMENT BULB TO ORDER
the bulb can be taken out from inside the oven just open the boor and look inside for a grill behind this is a light bulb, sorted easy
Oct 20, 2009 | Maytag MMV5207 Microwave Oven
No light inside of microwave
I hape that's .9 cubic feet, cause it it is 9 cubic feet that is on heckuva microwave!!!. Anyways, did the light once work? or are you curious if it supposed to have a light. If the light once worked, replace the bulb...
Mar 03, 2009 | Emerson Black Microwave Oven
Lamp bulb is out
You must remove the outside cover of the microwave to change the bulb.
The light cover inside the microwave should not be removed. It is held in place with contact cement.
For disassembly help see:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
The bulb should be available at most grocery stores, home centers, hardware stores, and places like Wal-Mart.
Sep 24, 2008 | GE JE1590 Convection / Microwave Oven
Where is the light bulb located?
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
LG LMVM1935 Convection/Microwave Oven Logo
178 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
