Question about Maytag Dishwashers
Dishes don't seem clean--there is a residue left on them--we changed dishwasher soap to see if that would help, but it didn't--the glasses havestuff inside
  • Maytag Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 08, 2010
Avanti dishwasher won't drain
hi could be two things... 1 could be you have food or broken glass in pump..it wont spin if anything there... u need to unplug from mains ...undo filter and remove ..you may have a larg metal filter remove too... you now have access to pump sump area... empty all water left in there with cup... it might SMELL :) when pretty much empty run VERY GENTLY around bottom of pump well... could be broken glass so do it slowley ... remve aything in there .. you will find a hole at bottom put finger in and turn propeller pump see if its stuck.. it it turns .and nothing is in way.. put back together and test dishwasher on quick wash.. if still not emptying change pump..
mark 07779933829 ===== TURN OFF AND UNPLUG FIRST=====
Nov 23, 2011 | Avanti DW18 Built-in Dishwasher
Soap residue on dishes. Used dishwasher cleaner yesterday. dispenser still has soap residue left. switched to powerball tabs today, but still have residue on dishes. Also, normal wash ran for 2 hrs. Seems...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Residue and Film on Dishes
heatman101
Asker
May 15, 2011 | Whirlpool GU1200XTLS Stainless Steel...
Dishes do not clean, although the water is hot and the soap dispenses. Dishes and glasses have a cloudy residue at times, and dishes sometimes have small food particles baked onto the surfaces.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 13, 2011 | Bosch Dishwashers
My Kenmore 16379 dishwasher is not cleaning well at all. We've tried powders, tablets, and gels with no better results. Glasses are dirty, dishes have soap residue.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
Jan 26, 2011 | Kenmore 16372 / 16374 / 16379 Built-in...
I am getting a lot of soap residue left on my clean dinnerware and glasses, like a dry soap residue. what can I do to fix that problem?
heatman101
Jan 12, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
heatman101
l'l
Sep 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Residue left in glasses and a film on the dishes
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jun 09, 2010 | Maytag 24 in. MDBH940AW Built-in...
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
Left over soap residue in glasses
you need to flush out the dishwasher, fill a cup with vinager and put it in the dishwasher standing up, then run the dishwasher thru a heavy duty cycle with no dishs. Then cut back on your soap, with new dishwashers and soaps you dont need much at all
Jul 08, 2009 | KitchenAid Food Grinder & Vegetable...
Dishwashers Logo
62 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
